Old 11-16-2018, 05:29 PM
BDFLYER BDFLYER is offline
Default Fuel protection for Vinyl wrapping
I'll be wrapping using Avery vinyl film. Unfortunately, one needs to put another clear film on top of the vinyl where fuel may spill into the vinyl (fuel + vinyl = really bad).
Any thoughts on the best film to use for this protective layer?
Old 11-16-2018, 05:55 PM
Is that what the mfgr said? While I probably wouldn't do it in an a/c, it's not uncommon to see vinyl tubing being used for gas line in some 'terrestrial' situations.
I'm toying with the idea of wrapping my wings, but fuel messing with the wrap would likely be a deal breaker. Is it the vinyl itself, or the adhesive that is vulnerable? Does this apply to all brands, or just this particular brand?
Charlie
Old 11-16-2018, 06:09 PM
Nedimbek's Avatar
Nedimbek Nedimbek is offline
3M says their wrapping vinyl is protected against gasoline (as long as its wiped off quicky). I would check with Avery but they should be the same.
Nedim Bek
Starting soon.
Old 11-16-2018, 07:17 PM
scrollF4's Avatar
scrollF4 scrollF4 is offline
Moderator, Asst. Line Boy
My RV-7A is now over 3 years and about 650 hours into an all-over vinyl wrap job by AircraftWraps.com using the 3M airliner-grade vinyl wrap. I have spilled far more 100LL over the wings overfilling the tanks than I am proud of. Absolutely zero impact on the vinyl wrap.
As mentioned above, make sure you're using the right vinyl. The 3M aviation stuff scoffs at 100LL.
Scroll
Sid "Scroll" Mayeux, Col, USAF (ret)
52F Aero Valley Airport, Roanoke TX (home of DR's Van Cave)
"KELLI GIRL" N260KM RV-7A tipper, YIO-360M1B with Danny King “Beautiful Doll’s” old Hartzell CS prop, dual PMAGs, dual SkyView, GTN-650, VPX, EarthX LiFePo4.
Nose Art by VictoryGirl.com. Smoke by Smoke System Helper.
90% done, 90% to go...
www.mykitlog.com/scrollf4/
Proud and grateful 2019 -=VAF=- Contributor
Old 11-16-2018, 07:38 PM
tomkk's Avatar
tomkk tomkk is offline
Do you happen to know the exact product was used on yours? I didn't find anything useful when I Googled Airline Grade vinyl. Thx
EDIT FROM SCROLL: I’ll look next time I’m at the hangar.
FOLLOW-UP EDIT FROM SCROLL: OK, it's the 3M 1080 airline-grade line of vinyl film.
Tom
Port Orange, Fl
RV-12 N121TK ELSA #120845; first flight 06/10/2015
RV-12 N918EN ELSA #120995 Eagles Nest Project
SPA Panther N26TK in progress
Old 11-16-2018, 07:41 PM
dtw_rv6 dtw_rv6 is offline
I have an automotive grade of 3M vinyl on my wings - and I can assure you that it easily stains and will dissolve under prolonged contact with 100LL.
Old 11-16-2018, 07:51 PM
BruceEicher's Avatar
BruceEicher BruceEicher is offline
I asked aircraft wraps once what their special trade secret product was. They brushed me off.
Six years and 500+ hours now on my 3M 1080 colors and Avery Conform Chrome. While I have polished aluminum on top of most the wings, fuel spills have happened fore and aft to the vinyl with no adverse affect.
I would seam seal arround the fuel caps for sure to help keep fuel from seeping under.
As always YMMV. ��
PS:
Cast vinyl is what you want, and the best grade and brands plays into it as well. calendared Vinyls you do not want. And pre colored solids will last longer than custom printed in most cases. Custom printed graphics add another variable based on the quality of the inks and such.
I have lots of the 3M 1080 in the Hangar, I’ll slap some on a sheet of aluminum and fuel test it, with the seam sealer, and without.
Bruce, Katie, Hana and RV-8 HulaGirl
Old 11-17-2018, 05:22 AM
snopercod's Avatar
Around my wing tank filler caps I have vinyl "100LL Only" decals. I haven't noticed any degradation in 4 years.
(2018 dues paid)
Old 11-22-2018, 12:52 AM
Major-Tom's Avatar
Major-Tom Major-Tom is offline
May I ask what the expiricend builders put under the vinyl? Is corrosion protection needed or can the wrapping take place on bare aluminium?
D-MDYZ Savannah-S built and flying www.savannah-blog.de
D-MDRV RV-12 #121128 enpenage kit
Donation made til August2109
WTB HomebuiltHelp DVD's for RV-12
Old 11-22-2018, 06:56 AM
scrollF4's Avatar
Nothing, unnecessary weight. The vinyl protects the aluminum. Also, we didn't get crazy with pinholes: The vinyl covers them. However, the vinyl will highlight imperfections in the composite surfaces, so you do want a decent surface sanding and gap fill job.
Scroll
