Old 06-22-2018, 11:35 AM
JDA_BTR JDA_BTR is offline
Default Beringer parking brake
Bled my Beringer brakes today with masters horizontal going smooth using a little oil can to send the fluid from the calipers to the reservoir.
Parking brake question : does pullin the brake actuate the brakes or isncorrect procedure to push the toe brakes and the lock them withbthe parking brake?
Ser 104142, RV-14A
N1463
Urologist, AME
Old 06-22-2018, 11:58 AM
rleffler's Avatar
rleffler rleffler is offline
Typically, while holding the toe brakes, then set the parking brakes. All the parking brakes does is to hold the current hydraulic pressure being applied. Be forewarned, most parking brakes will tend to bled over time and slowly release pressure. In other words, only use for short periods of time. i.e. long enough to get out of the aircraft and place chocks.
Bob Leffler
N410BL - RV10 Flying
http://mykitlog.com/rleffler
Old 06-22-2018, 12:22 PM
Understood!
Does anyone know the torque spec for the caliper bleed screw? I canít find it in the beringer docs.
Ser 104142, RV-14A
N1463
Urologist, AME
Old 06-22-2018, 02:01 PM
They dont publish it, but snug 13 in/lb should work.
Tom
Ridgeland, SC
Old 06-22-2018, 02:53 PM
MED MED is offline
Understood!
It is stamped on the caliper: 148 in-lb.
MED
140236
N435MD
Old 06-22-2018, 03:10 PM
Thatís right for the banjo fitting but too high fornthe bleed screw?
Ser 104142, RV-14A
N1463
Urologist, AME
Old 06-22-2018, 03:34 PM
MED MED is offline
Then, I don't know. Snug? Until it stops leaking? Nothing in the installation and maintenance manual.
MED
140236
N435MD
