Does anyone have pictures of their AFP fuel injection system with purge valve pictures.
I would like to locate my fire wall pentitration location for the fuel lines and mixture, throttle, and purge vavle cables.
For your purge line FW penetration you need to drill where it is most suitable on the backside.
A hose from the purge valve will fit to almost any location on the forward side of the firewall.
Fuel lines and actuator cable are also somewhat dictated by where the throttle quadrant and the fuel selector are located in the cockpit.
You can just follow Van's instructions on the fuel lines and actuator cables.
Seriously now, that was an early picture and replaced during the 40 hour test phase before it failed.
The cable is a .063 McFarlane actuator cable without threads.
It is pinched between 2 washers and through the bolt, sandwiched inside the fork end. With the addition of a return spring, the worst thing that could happen is it would stay in the on position.
I'll still buy both of you a beer if I ever meet you
