I drilled a few strategically located 1/4" holes in the cavities of the door after it was bonded, mounted, and closed. I then squirted in minimal expansion spray foam until it foamed out the holes, let it cure and trimmed off the access, dug out a little foam around the holes and patched it up with some flox. Along with adding a little insulation, the foam creates a stress skin structure which adds a little rigidity to the doors. I had to dig out some of the foam for the door mechanical mechanisms but that was not a big deal.
