Hello GDL 82 Users,
As some of you are aware, the initial GDL 82 software could transmit a couple of "uncloaked" ADS-B Out messages with real aircraft ICAO address and Flight ID on power-up, even with the transponder code set to 1200 and the Anonymous switch active.
Many of you requested this be improved, and we are happy to report that this work is complete. The new V2.01 software includes improvements to make sure that a system starting up with the Anonymous mode switch active and a transponder code of 1200 will enter Anonymous before transmitting any messages thus safeguarding the true ICAO address and Flight ID of the aircraft.
We also created a special non-certified aircraft service bulletin with instructions on using the same PC installation tool and USB interface you originally used to install/configure the system to install the new software.
The service bulletin and V2.01 software can be downloaded from the GDL 82 Software Download page. There is one download for the software plus service bulletin, and a second for the PC tool if you need it. The PC tool is unchanged.
Let us know if you have questions.
Steve
Steve
