Old 05-20-2019, 03:19 AM
chris mitchell chris mitchell is offline
Default Help with Garmin G-5 installation
Hi All,
I'd be grateful for thoughts on my recent Garmin G-5 installation in an RV-7. AS part of this work I took the opportunity to install a heated Garmin pitot and to re-plumb the entire dynamic and static system using the SafeAir/Dynon system of flexible tubing and connectors, and a new ASI (with appropriate speed marks for an RV-7 .
We flew an East-North-West-South course to calibrate the new ASI and plumbing with the ground speed taken from the Garmin 430. The results show that the calculated TAS taken from the ASI (corrected for altitude and temp) is within 1% of the ground speed, with the ASI slightly over-reading. So far so good. At least there are no pitot leaks!
However, the ASI and G-5 comparison is much less good.
The instruments agree at 110kts IAS, but at higher or lower speeds - 50kts up to 160 - the G-5 is reading up to 4 kts too low at both the higher and lower speeds.
Which to believe? Well the ASI agrees nicely with the ground speed calculations - so the G-5 is reading low.
I have read and re-read the installation procedure. Can't see anything to help. I did recheck the plumbing, looking for kinks etc but it all looked good. The G-5 is running on its internal GPS antenna - would that make a difference? I can't see that it would. Any other good ideas?
THe original reason for installing the G-5 was as an attitude indicator. I suppose the simple pressure driven ASI and Altimeter are highly unlikely to fail so maybe the easiest thing is to disable the ASI on the G-5, but having plumbed it I'm reluctant to do that. I'd much rather find the problem and fix it.
Many thanks
Chris
Chris Mitchell
Repeat offender;
RV-8, QB, built, flown 150 hours, sold;
RV-4 - attempted repair, rebuild and remediation - abandoned and junked ;
RV-4 fuselage and wing kits - both at QB stage;
2015-2018 dues paid!
Old 05-20-2019, 08:19 AM
Pat Hatch's Avatar
Pat Hatch Pat Hatch is offline
Smile
Chris,
Why not set up a water manometer to verify your in-flight results?
There are plenty of resources on the web that describe the process and the math involved. Pretty simple to set up and to calibrate your instruments.
My money is on the G5! My experience installing G5s and G3X Touch together (GSU 25 ADHRS vs. G5 internal air data) is that airspeed readings are usually within a knot of each other.
Pat Hatch
RV-4 (Gone to RV heaven)
RV-6 (N44PH - Flying)
RV-7 (Sold)
RV-8 (Builder & Avionics Installer)
www.phaviation.com Trim Relay Boards/Flap Actuators
www.pathatch.com/blog (Photography)
Track Me
Old 05-20-2019, 09:52 AM
Pat, please just walk me through your thought processes here.
The ASI (actually calculated TAS) correlated well with the GPS ground speed over 4 legs. The G-5 is ok at 110 but otherwise is 3-4 kts slow after calculating TAS, compared to the GPS measured ground speeds.
It seems to me that, based on our flight test data, the ASI is pretty accurate and itís the G-5 at fault.
Maybe Iím just being slow!
Chris
Chris Mitchell
Repeat offender;
Old 05-20-2019, 10:00 AM
Ralph Ketter Ralph Ketter is offline
Default Static System OK
I would check the static system for leaks as well as verify the airspeed readings with a manometer test.
Static Requirement reference at:
https://www.govinfo.gov/content/pkg/...sec23-1325.pdf
Helpful EAA video at:
https://www.eaa.org/Videos/Hints-for.../5002807430001
Ralph Ketter
La Luz, NM
RV-6 Flying
Old 05-20-2019, 11:30 AM
Pat Hatch's Avatar
Chris
Chris,
Yes, I agree, it would appear that the G5 is the erroneous one considering your TAS in-flight data. The manometer test will just help you confirm that as well as verify that you don't have a leak. One of the things I like to do as a quick check for pitot leaks is to inflate a small party balloon and slip it over the pitot tube. This usually gives an indication of around 100 knots, but if you leave it on for a while, it should hold pressure. If the balloon deflates, you have a leak. Just a quick troubleshooting technique. Again, it would appear that a leak would affect both instruments equally, but then again you might have an internal leak in one of them. It's probably a calibration issue, but it's worth investigating other causes. Please let us know what you find!
Pat Hatch
RV-7 (Sold)
Track Me
Old 05-21-2019, 02:00 PM
n982sx n982sx is offline
I've found the G5 to work well and compare well with other instruments.
Just to clarify, are you using the four leg spreadsheet available from the test pilot school or similar? Inputs of four ground speeds and tracks derived from four legs on headings 90 degrees apart?
If so I would believe your results, providing you're comfortable with your TAS conversions. I have OAT data available to my systems so my systems have been doing those calcs automatically. I did do some manual calcs to verify them.
Bob Meyers
Built and Flying RV-14A N626KM SN 140093 http://n626km.com
Built and Flying Sonex N982SX http://n982sx.com
Old 05-23-2019, 01:12 AM
Cumulo Cumulo is offline
Interesting. It may be a case of two opposite errors compensating and giving the right answer. I assume that your flight calibration is accurate. My money is also on the G5 being right.
My guess for the other error is that the static port is a bit off at higher speeds. The static port is pretty fussy with respect to location and surface. The pitot not so much as long as it is within a few degrees of flow, which is usually the case at higher airspeeds.
Two wrongs make a right?
Ron
