Removing the prop governor
Chattin35
This might be a dumb question...
If I remove the prop governor without first draining the engine oil, will I make a mess? Not sure how the oil system works at that spot on the engine.
Thanks.
(IO-360-M1B / MT governor)
Removing Governor
The governor is well above the oil level in the sump so no worries there, but there is oil in the governor and the line that goes forward to the prop so you will be dealing with about a cups worth. If you are only removing the governor unbolt it from the drive pad and leave the drive pad bolted to the rear case.
Don Broussard
RV9 Rebuild in Progress
57 Pacer
Don Broussard
57 Pacer
Except if it is a dual mag system. The drive pad is integral to the pump.
