I'm going to use the holes in my RV14A tail to install a CI-158C underneath where the designer intended a transponder antenna be placed (don't need that there). Does anyone know what hardware is called out for the CI-158C?
Are the holes in the puck countersunk for a particular size screw?
On second thought the hole spacing might be wider for this than what is already drilled in the tail....
