DennisRhodes
Is there an "easy" way to check the timing on a Plasma II+ using the HAll effect module attached at the Mag pad? The instructions provide a positioning procedure for initially installing the unit on the pad. Also suggest a induction timing lite to check the timing at 25 deg with engine under load.
Can the little green lite either "off or on" as the prop is pulled thru 25 provide some assurance that the 25 deg setting is still good ? Mine seems to flash at around 10. Aside from pulling the unit off and resetting the mechanical position or pulling the MAP line and running the engine at load with a timing lite is all I come up with.
