Larco
I do not know of anyone that has done the thicker disc upgrade on a taildragger but I am leaning towards doing it. While talking to Parker/ Cleveland about it they concurred that unless you change the hydraulics the brakes will not be stronger but with the thicker disc you will have less brake fade. That is what I am after and less heat might be easier on the pads.
I will be replacing worn rotors soon so this would be the time.
Hoping an engineer in this field of expertise will comment on this. I do not want a stronger brake just less fade.
