170 driver
I was wondering if anyone has found anything that can be used to overcoat the exposed sealer on the outside and rear of the tank to prevent the blue dye from a small leak from softening the sealer in a big area and causing massive rework? It seems that there should be some coating that is impervious to the blue dye. This could make small leaks an easier repair.
