alpinelakespilot2000
Need help troubleshooting...
Went to start up today and, out of the blue, could barely get the prop to move. It would move maybe 20-45 degrees and then seem to get hung up. After a couple seconds with the starter switch engaged I would get a bunch of clicking noises on the firewall and still no more movement on the prop. I tried this 3-4 times all with the same result. Pulling the prop through by hand felt normal... nothing binding up.
I have about 200 hours on everything, have never had cranking issues in the past with my SkyTec. When I pulled the cowl I checked battery voltage and it showed 12.4V, even after having tried to start the plane 3-4 times. So I'm thinking the issue is downstream of the battery. Further, based on an old thread started by Paul Dye, I'm very suspicious of my starter relay. http://www.vansairforce.com/community/showthread.php?t=90977&highlight=relay. Except that this happened with no warning for me, my situation seems similar.
I'm planning to at least try cleaning all the big power wire terminals first, but does the above sound like a starter relay issue to you? It seems like not very many hours for it to fail, but perhaps I wasn't careful enough about not letting the terminals rotate while tightening the cables down when I first installed it.
Regardless, if it is the solenoid, Van's number is 24021 http://www.vansaircraft.com/cgi-bin...90-104-501&browse=electrical&product=start-sw and I think I found the same thing/same number at Napa for $24. http://www.napaonline.com/Catalog/C...oids-SPST-COLE-HERSEE/_/R-TWR24021_0144317761 Just want to be sure they are the same.
Thanks for any help.
