Another #2 spring rubbing
I fit my cooling shroud exactly as outlined, trimming the butt joint for the oval inlet only to the scribe line and fitting it with no overlap. My cowling was all fit with the engine and spinner in place and the scribe lines were nearly spot-on. However, I also encountered minimal (1/8") clearance between the spring and the cooling shroud and as expected, it began to rub with engine movement during the first engine run. I had to basically do similar fiberglass work to what John described earlier in the thread, cutting out an elongated area and then building it back up with a trough. I made mine smaller, as my header seems to have adequate clearance. Just hope I won't have to revise it later.
I think that there is just enough variability in all of these close fitting parts that even installed properly, some will have less than adequate clearance. While the alteration was not difficult, would be nice if a slight change was made in the cooling duct fiberglass mold for future builders such that there was a bit more clearance in this area. It does not appear as though a 1/4 inch drop in the area would have any negative impact on airflow to the radiator.
Jeff
