You will need -
..paper cups
..measureing cup(s) plastic
..tongue suppressor or similar stir sticks
..mask(S) Do Not Breathe Flox or MicroBalloons
..many sizes - widths of masking tape
..Duct Tape
..lacquer thinner etc
..MLK and or Naptha
..and the band plays on
Don't use paper cups, stop by the grocery store and pick up some of the Glad disposable containers, they clean up very easily, once the epoxy has hardened.
No need for the measuring cup(s) if you buy the West pumps. The pumps do a good job of measuring the epoxy and hardener, one pump of each, and go mix it.
I'm not sure what the masking tape is for but I use the clear plastic packing tape. Put some down and you can lay your fiberglass over it and when it hardens, the glass will pull right off.
Also, petroleum jelly works great as a mold release agent.
Another trick I heard about the other day but haven't tried is to put down a layer of 4 mil plastic, place your FG cloth on that, drip some epoxy on the cloth, put another layer of 4 mil plastic over, then squeegee in the epoxy so it covers all the cloth. Once that is done, using the pizza style cutter, cut your shape through the plastic. Then peal off one piece of plastic and take the other, which is holding the wetted fiberglass, over to the part you need to glass. That sure sounds simple.
Oh, and don't forget the peal ply.
