Any wrinkling you might have seen has nothing to do with a difference in leg stiffness. It is just that it is totally different points (and types of structure) that the two types of gear are transferring their loads too.
The load the legs absorb and transfer to the structure they are attached to are pretty close to the same for both models if the test is done correctly.
I do not remember whether there was any permanent deformation in the gear legs after the worse case ultimate test, but it doesn't matter.
Remember..... any load capabilities above limit are owned by the engineers. The structure must be able to take loads up to and including limit, over and over, with no damage or deformation. Anything over limit, up to and including ultimate, there can be permanent deformation, just not catastrophic failure (a gear leg can bend, just not totally fail).
In a (very bad) land that induced loads near ultimate, the brake disks very likely would contact the runway/ground.
BTW, if anyone ever does experience a landing that induces Limit loads, the will probably describe the landing as a crash (Meaning it is way worse than what resulted from what people think was their worse landing). So I cant imagine what a landing that induced ultimate loads would be like.......
