ron sterba
Dawg C-1...right lower corner. Axle bolt shows three washers. Large washer next to bolt head,, it’s at this point my point arises.,, the next two washers are 616 @.062 and a 616 -L at .030”. Combined these two washers are .092” thick. Now the wheel pant bracket is ( U-713 ) and it’s .060” thick. When I slide this bracket (U-713 )on as described over these two washers (equalling .092” )) on (page section 10-7 and just under”wheel pant & U-713C support bracket) my bracket is loose because of the.032” gap between the wheel fork and the first washer that’s under the bolt head. Question is this bracket supposed to free float over those two smaller washers??? It sorta indicates that in the sentence ( begins with”tape a 7/8”). Now I just took out the 616 - .062” washer and put in a .030” washer and the two now equal the thickness on the bracket.It tightens up nicely. So is there a significance to the roominess of this area? I know this isn’t a space ship Iam building but it’s MY space ship�� Could a vibration occur from this bracket. Thanks
Cheers
Ron in Oregon
Cheers
Ron in Oregon
