Go Back   VAF Forums > Model Specific > Rocket
  #71
Old 08-14-2016, 06:17 AM
mscheuer's Avatar
mscheuer mscheuer is offline
Default PMA4000
Thanks for selecting our PMA4000!
Mark Scheuer
PS Engineering, Inc.
VAF Advertiser
Old 08-14-2016, 12:44 PM
swaneymj's Avatar
swaneymj swaneymj is offline
I'm very happy with the PMA-4000. Great audio panel/intercom. I was even able to install a separate volume control in the rear seat. Perfect for any tandem aircraft!
Old 05-01-2017, 08:48 AM
logansc's Avatar
logansc logansc is offline
Default New Panel in #160
Not done with this install yet, but it is now operational even if not fully sorted out. Here are some shots from yesterday returning from Columbus, GA.
2250 and 20.6" (WOT) at 11,500' and truing 190ktas on 12.9 with a Slick on the left and CPI on the right. You can see that the three right side EGT's are reading way low (no idea why). You can also see my wingtip camera in action (used principally for safer taxiing). And yes, there is a discrepancy between my steam gauge ASI and altimeter and the same displays on the AF5600 (they use different static sources). I still have some "tuning" to do there too.
Regards,
Lee...
Lee Logan
Ridgeland, SC (3J1)
F1 Rocket #160 flying
Old 05-01-2017, 09:06 AM
Mjuckes Mjuckes is offline
Default Panel
Nice!! Clean install, Good layout. Gotta like the glass!!
RV-4 flying
F1 Rocket
Old 05-01-2017, 09:07 AM
swaneymj's Avatar
I like it! Where did you mount the camera?
Old 05-01-2017, 02:53 PM
logansc's Avatar
Mark: In the leading edge of the fiberglas wingtip. I did't want view to be through the prop arc in order to avoid the shuttering effects.
Works pretty well, even though it is offset.
Lee...
Lee Logan
Ridgeland, SC (3J1)
Old 05-01-2017, 03:59 PM
swaneymj's Avatar
Red face
I made a blister on the left gear leg that seems to work okay, but I still see the prop at times. It's displayed on one of my Dynon Skyview displays. What kind of camera did you use? The automotive backup camera I'm using is, again, ok but I'd really like something better. I think I paid $25 for it. You get what you pay for.
https://photos.google.com/u/2/share/...hOSUxPdlFKOTh3
Old 05-03-2017, 01:05 PM
logansc's Avatar
Mark: Your Rocket is so cool looking---you've done a beautiful job on it.
My camera is a "Weatherproof Camera". There is no model number or name on the one piece of documentation I have on it. It is a so-called, color "bullet camera", 12v, 3" long and 3/4" in diameter with something like 450-550 lines of resolution.
You can Google them or start here: https://www.amazon.com/ePathChinaŽ-7...SIN=B00OQ0Y2A4
There are a lot of them to choose from, just get color and about the size I got and you should be fine.
Lee Logan
Ridgeland, SC (3J1)
Old 05-16-2018, 05:43 AM
Adrian Bonwitt Adrian Bonwitt is offline
Default Remote transponder
Looks great!
Are you using a remote mounted transponder?
Old 05-16-2018, 01:27 PM
swaneymj's Avatar
For N76TR I've installed a Garmin GNS330ES. The Dynon remote was not available at the time I did my panel.
