Old 12-12-2009, 08:14 AM
N208ET N208ET is offline
Default Drilling tank attach brackets to fuse 8A
Ok, maybe I am missing something here. I have got the wings on and have prepared the tank attach brackets that attach to the fuse, question is, do you drill the holes from inside the fuselage and out through the bracket. I already made the holes in the bracket per the plans, maybe that was a mistake. What am I missing here.
Randy
8A
Old 06-26-2012, 03:54 PM
RVG8tor's Avatar
RVG8tor RVG8tor is offline
Default Any answer
Randy
8A
Randy did anyone answer this. I just made my brackets and have not drilled the fuselage attach holes in the bracket, I only marked the location. I have wire and fuel lines back there, my thought was to drill from the fuselage side after marking locations that will best suit where my wires run.
Cheers
Mike
Mike "Nemo" Elliott
RV-8A (First Flight 12-12-12!)
T31
N800ME
www.mykitlog.com/rvg8tor
Dues Paid 2018
Old 06-26-2012, 07:21 PM
Default I think you can drill from the inside of the fuse
Since you didn't drill out the tank attach bracket hole like I did. I ended up using a close quarters 90 degree drill to drill mine from the outside in.
Old 06-26-2012, 07:42 PM
RV8RIVETER's Avatar
RV8RIVETER RV8RIVETER is offline
I had some plexi from Home Depot and made a clear template. Easy to see the holes, drill from the outsie and then transfer to the bracket.
One more thing. Measure the clearance with a straight edge to the top of the wing skin, to simulate the gap fairing. I made mine exactly per plans and the gap fairing was hitting the top of the bracket. Had to file it down some. Talked with a new neighbor who just had the first flight of his -8 and the same thing for him as well. Much better to correct now.
Wade Lively
-8, Flying!
N100WL
IO-360A3B6D, WW 200RV
Old 06-26-2012, 08:25 PM
bruceh's Avatar
bruceh bruceh is offline
I just did this with my -9A. I was able to get the drill on the attach bracket from inside on one hole and used the angle drill for the other hole.
I just started the holes, then took off the bracket and drilled them out the rest of the way on the drill press.
Bruce Hill
RV-9A N5771H flown over 600 hours!
2018 VAF donator
EAA Tech Counselor
Old 04-30-2018, 06:01 PM
SgtZim SgtZim is offline
[quote=RV8RIVETER;673461]I had some plexi from Home Depot and made a clear template. Easy to see the holes, drill from the outsie and then transfer to the bracket.
That is sheer genius!
RV-8 slow build
IO360-M1B Sensenich fixed pitch
Garmin G3X
GTN 625
GNC 255
GTR 20
GTX 45R
G5 x 2
Facebook "log" https://www.facebook.com/BZsRVproject/
Old 05-02-2018, 12:39 PM
Default confession
I goofed: I predrilled the 1/4" hole in the fuselage bracket and then tried match drilling into the tank bracket with less than optimum results.
What I SHOULD have done is do a careful measure of both brackets overlaid and then drilled from the front - tank bracket into the fuse bracket.
However. I rechecked all my dimensions, and had I done the latter, I would have found that when mounted to the tank and the fuselage, the brackets do not overlay nicely like the picture on the plans. I would / will reshape the fuselage bracket to put the center of the radius in line with the center of the radius on the tank bracket - about 1/4" lower. I'm just hoping I don't need to redo the tank because of the too high hole.
RV-8 slow build
Garmin G3X
GTN 625
GNC 255
GTR 20
GTX 45R
G5 x 2
