Old 05-16-2018, 06:42 PM
JonJay's Avatar
JonJay JonJay is offline
If you are going to buy a tap and die set, and use it for other purposes than tapping aluminum for an RV, buy a good set. HSS (high speed steel), USA, etc....
The first time you snap off a cheap Chinese made Harbor Freight or other brand in a part, whatever you saved just flew out the window.
If you use a tap often, you will side load one and accidently break it off. The better brands, like Irwin, are just tougher and less likely to snap, especially the small sizes.
ACE Hardware sells individual Irwin(Hanson) taps and dies if you don’t need/want to buy a full set.
The small general tap and die set from Irwin will cost you about $125 in SAE or Metric.
Also, you can occasionaly find used manual tapping machines on CL. These are good for repetitive hole tapping on flat stock. I picked up a quality US Made one for $50, a $250 plus machine.
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
Old 05-16-2018, 07:21 PM
Champ's Avatar
Champ Champ is offline
Only times (that I remember) using a die was on the SS baffle tie rods I used under the cylinders instead of wire. Even with a HSS quality die had to take it real easy on the SS with lots of back & forth. Also used a #6 tap on a hole into the gear tower lower weldment for the forward attach screws on the upper gear leg intersection fairings. It wasn’t practical to use a nut plate here (more holes and a pain to buck) and another nut in the gear tower would have made me even more nuts.
Dennis Enns
Kingsville, ON
Bellanca Champ 7ACA since 1986, restored 1990.
RV-8 IO375, Hartzell CS, dual PMags.
2019 Donation In
Old 05-16-2018, 09:01 PM
wilddog wilddog is offline
You are going to like those Wiha screwdrivers. Quality makes a big difference.
Old 05-17-2018, 01:11 AM
Z-EDD's Avatar
Z-EDD Z-EDD is offline
Originally Posted by rv7charlie View Post
For a completely stock build, you probably don't really need a set.
I would argue completely the opposite. On my stock RV-7 slider I have so far used 6-32, 8-32, 10-32 and 1/4-28 taps, all as specified on the plans. However if you deviate from stock there are ways around most of those.
To the OP, be aware however that I initially bought a cheap HF set but found it included none of the sizes needed! When I checked at sears I also couldn't find a set that had all the sizes, so you'll need to check that carefully.
And if you need an excuse to buy tools don't forget that each tap needs a number size drill bit for the hole, so you might as well go ahead and get a full set of 1-60 number size bits, another buy I have never regretted. Almost every month these days I also wish I'd got the letter size set.
Ed Fleming
RV-7- Wings done for now, canoe riveted.
Harare, Zimbabwe
Paid 2017
Old 05-17-2018, 09:05 AM
Paddy's Avatar
Paddy Paddy is offline
Default Plans call for several taps and at least one die.
In my slow build -10, I can remember being required to tap threads in the T section extrusion for the tie-down points in both wings and tail, as well as #6 threads in the longerons near the tail to secure the empennage fairing. The FWF section called for cutting threads in the baffle tie rods, although I found those next to impossible to thread properly and ended up buying pre-threaded rod for that part.
Flying as of 10/30/16 after 8 yrs building
Old 05-17-2018, 10:14 AM
tyconnell tyconnell is offline
Since I have a PDF preview plans, I searched for "tap" in it and ran across the list of ones you will need in the tools section and a number of spots where they get used. I'm surprised by the number of times I don't think to do that first.
That list is:
1 x 1/4-28 Tap
1 x 5/16-24 Tap
1 x 3/8-16 Tap
1 x 3/8-24 Tap
1 x 4-40 Tap
2 x 6-32 Tap
1 x 8-32 Tap
1 x 10-24 Tap
I'm not sure why you would need 2 x 6-32 Taps. Also, I didn't see all of these called out in the manual - some places say "tap this, see drawing X" kinda thing. Maybe they are in the drawings.
Anyhow, once again, I appreciate all the feedback here. And the "permission".
Ty Connell
Atlanta, GA
EAA Chapter 690
VAF dues paid monthly
ty.connell@gmail.com
N997TL reserved
RV-9(A?) empennage in progress
Old 05-17-2018, 10:42 AM
Boy, Ed; how far do you need to go, to make yourself feel significant? ;-)
I suppose that a list of 4 taps (and no dies) could be considered a 'set', if you're using the strict mathematical definition. And I suppose that if you extract one sentence, out of context, from a multi-paragraph post, you can make yourself look like a higher authority.
To help you out, here's a HF set that is pretty cheap, and includes the sizes you list. Most vendors include a list of what's included, if you read before you purchase.
https://www.harborfreight.com/hand-t...set-63016.html
Charlie
Old 05-17-2018, 11:44 AM
wirejock's Avatar
wirejock wirejock is offline
Default Irwin
I just bought singles as required. I might own five or six.
Ace
Irwin brand.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
Old 05-17-2018, 12:14 PM
JonJay's Avatar
Ace
Irwin brand.
About $5 each and you have a quality tool that will last and shouldn’t break.
Bucker Jungmann
RV1 - Proud Pilot.
Old 05-17-2018, 05:34 PM
wirejock's Avatar
Default Ace
Less. I get a senior discount!
Actually, living in a tiny hamlet (population 6,000), my only aviation supply store is Ace. I go in so often, they take really good care of me.
Larry Larson
Estes Park, CO
Disclaimer
