Old 05-16-2018, 03:25 PM
tyconnell tyconnell is offline
Default Tap (and die) set
I don't own a set yet. I'm currently finishing up the left elevator on my -9A emp kit. So that the hardware would not get lost, I screwed in the trim cable cover plate, and two of the SS screw heads stripped during the process.
From what I gathered reading here, this is fairly common. The screwdriver I used was not so great. Ordered a Wiha PH #2 to see if those are worth it. Also, I will use Valve Grinding Compound on the threads which is supposed to help.
On to the question - the first thing I thought of when I stripped the heads was "these need to be tapped." I did some reading here on VAF, and there is a never-ending-debate regarding tapping plate nut vs. not.
I know what a tap and die set is used for in general, and there are a couple of posts by fellow VAFers who swear by having a set. But if you're not tapping narfed plate nuts, what tasks during the build are accomplished using a set?
Ty Connell
Atlanta, GA
EAA Chapter 690
VAF dues paid monthly
ty.connell@gmail.com
N997TL reserved
RV-9(A?) empennage in progress
Old 05-16-2018, 03:38 PM
Raymo's Avatar
Raymo Raymo is offline
I have the powder/wax BoeLube and sprinkle that into the screw tray or bag prior to installing. It cuts down significantly on friction and helps avoid the stripped heads.
Nut plates are designed with friction as a locking device (e.g. lock nut). Running a tap through essentially ruins that locking function.
I have owned a tap and die set for 30 years but didn't use it when building except where the plans specified it for screw installation in the aft longerons for empenage fairings.
Ray
O-360-A4M w/ AFP FM-150 FI, 1 PMag, Vetterman Trombone Exh, SkyTech starter, PlanePower Alt
All lines by TSFlightLines
NSDQ
Old 05-16-2018, 03:44 PM
longline longline is offline
Default Tap and Die
Ty, you use the valve grinding compound on the end of the Phillips bit to decrease slippage of the bit, not on the threads. You probably meant this, but it came through, to me, as you were going to put it on the screw threads...
I have used various different lubricants on nut plates. Currently I am using Gulf brand canning wax. This does help get the screws in/out, but sometimes it just makes sense to "ease" the threads a very little bit with a tap. Experiment with a nut plate to figure out how to ease the force required to insert screw without loss of the locking feature.
Old 05-16-2018, 03:48 PM
alpinelakespilot2000 alpinelakespilot2000 is offline
Originally Posted by tyconnell View Post
...and two of the SS screw heads stripped during the process.
Your solution for these screws is not a tap and die, but rather a screw extracter set from your local hardware store. You first drill a small pilot hole in the head of the screw and then screw in the extractor in a counterclockwise direction. Should pull the mangled screw right out.
Once a platenut has been used a couple times, they tend to loosen up significantly. A little Boelube on the screws helps as well in the first installation. I only tapped platenuts where Van's specifically instructed and have not had any trouble with screws after the first or second time.
Good luck.
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2019
Old 05-16-2018, 03:52 PM
RV6_flyer's Avatar
--- snip ---
A tap and die set is not necessary to build an RV kit aircraft.
The tap and die sets that I own are 40-years old. They are nice to have when one finds a damaged thread on a bolt or nut and a NEW bolt, nut, or plate nut is not available. It can be used when needed to repair a part that should have been replaced.
As others have said, one should not use a tap on plate nuts but sometimes there may be one plate nut that needs it threads cleaned out removing its locking feature. Not something that you will do to every plate nut but something you may do to add a fastener on a plate nut that needs replaced but you do not have the time or access.
Any cheap set is nice to have in the tool box. Better quality individual taps can be purchased if you need them.
Gary A. Sobek
NC25 RV-6
Flying
3,300+ hours
Where is N157GS
Building RV-8 S/N: 80012
Old 05-16-2018, 04:24 PM
Go to your local hardware or plumbing supply store and get a bees wax toilet sealing ring. Must be bees wax, not some modern synthetic substitute.
Use a dab of bees wax on the threads of your SS screws and/or the nutplate threads. This will allow easy insertion of the screw yet still maintain the locking ability of the nutplate.
One toilet ring should last you a lifetime and be under $10.00.
Bees wax is also good for taping aluminum, and other jobs in the shop.
As for the tap set-------Like Gary said you should not need one to build an RV. Also, do not run the tap through the nutplate-----you are destroying the locking function of the nut plate if you do. They are meant to grab and hold on to the screw/bolt in normal use.
One last thing-------the first time you insert a screw into a new nutplate, not only use a dab of bees wax, but drive it by hand------stay away from the power driver.
Old 05-16-2018, 04:28 PM
Actually, I did mean on the threads, and not on the Phillips bit, so I had that all wrong!
Originally Posted by alpinelakespilot2000 View Post
Your solution for these screws is not a tap and die, but rather a screw extractor set from your local hardware store. You first drill a small pilot hole in the head of the screw and then screw in the extractor in a counterclockwise direction. Should pull the mangled screw right out.
Sorry, I wasn't more clear in my post. The question regarding tap and die set wasn't for removing the screws - it was for "what else are they used for" since I had inferred, from other posts, that tapping plate nuts was "bad". I actually own a set of screw extractors having broken off bolts in metal before.
Originally Posted by Raymo View Post
I have owned a tap and die set for 30 years but didn't use it when building except where the plans specified it...
Darn, I'm a bit of a tool junkie. Was hoping someone was going to give me an excuse here.
Ty Connell
Atlanta, GA
EAA Chapter 690
N997TL reserved
Old 05-16-2018, 04:45 PM
I get the worry that re-tapping a plate nut may defeat its purpose. But be aware that it's not uncommon to have the heads of A/N #6 steel screws twist off while *installing* them in some plate nuts. I'd call that a bit more tension than actually needed; yes? And since it's spring steel that flexes back into a circle when a tap is run through it, it would take many re-tapping operations to truly defeat its function.
On owning a set of taps: I've got a few decent quality taps in the common sizes, and el-cheapo full sets from Harbor Freight in both standard and metric. The HF stuff won't last long tapping steel, but I've used them for aluminum a lot (non-typical stuff, to be sure). I've also got a set of HF pipe taps & dies, that have lasted through plumbing gas lines through an entire 3000 sq ft house and are still going strong.
For a completely stock build, you probably don't really need a set. But I've found lots of uses for mine. Consider locations like the anchor points for the shock struts for a tipup canopy. A tapped plate eliminates the need to get a wrench into the top longeron assy to hold the nuts.
FWIW,
Charlie
Old 05-16-2018, 05:15 PM
DanH's Avatar
DanH DanH is offline
Ok, permission granted
Seriously, there are a number of nutplate locations where frictional locking power just isn't necessary. For example, I don't hesitate to tap the four nutplates holding an EFIS in the panel. Same for the seat pan/mid floorboard/footwell panels in the -8. Even if those screws came out (they don't) it wouldn't hurt anything. Locking just makes inspection a pain in the butt.
Lockers are for locations that would create a hazard to flight.
Dan Horton
RV-8 SS
Barrett IO-390
Old 05-16-2018, 06:00 PM
scard's Avatar
scard scard is offline
< If Dan is going to get serious >
Hmm, me too. But, "He who dies with ... wins." I don't look for excuses, for I spend a lot of time seeking forgiveness .
I promise, you WILL find an incredible use for that "tap and die set" (insert whatever $$,$$$ tool) to fix the tiniest thing around the house in an instant. Then it is up to you to channel you're inner Steve Jobs, "It's Magical isn't it!?".
Just be careful what you ask for. A wise family member said the other day, "You can only play with so many fun tools at a time. Then you have to hire people to operate them. That turns into work real quick and takes all the fun out of it."
Oh, I'm sorry, you were just talking about a tap and die set. FORGEDABOUDIT!.
Scott Card
CQ Headset by Card Machine Works
RV-9A N4822C flying 1900+hrs. / Cedar Park, TX
