Old 05-16-2018, 11:38 AM
GregMac GregMac is offline
Default FLOOR BRAKES
Has anyone who has done an upgrade to overhead pedals still got the floor mounted stuff ? Iím looking to put brakes on the CoPilot side of my RV6 fitted with floor pedals. Vans doesnít stock any of this now, so even the brake pedals to fit the rudder pedals would be good, I can source all the rest (cylinders etc) elsewhere if needed. Cheers Greg
Old 05-16-2018, 05:04 PM
Larco Larco is offline
Hi Greg, My take is, there are probably not many people that upgraded because of the same issue as you have. Hopefully someone has them available. If not I would recommend google to find some salvage yards that may have some early RV6s and could sell you the parts?? Just a thought.
Old 05-16-2018, 06:44 PM
gmkonrad gmkonrad is offline
Default RV6 copilot brake pedals
PM sent on brake pedals
Old 06-01-2018, 05:09 PM
XPPilot XPPilot is offline
Default RV6A copilot brake pedals
I am in the same mission to find copilot side brake pedals and needed parts.
If you have those available please PM me.
Old 06-02-2018, 10:08 AM
Snowflake's Avatar
I guess the other option would be to upgrade to overhead pedals, parts for which *are* readily available...
Rob Prior
Old 06-02-2018, 06:06 PM
Russ McCutcheon's Avatar
Russ McCutcheon Russ McCutcheon is offline
Did anyone call and ask Vanís if they could order these little brake pedals? I think I have the parts ready to weld, probably need the stampings from Vanís but they probably have them. We used to build lots of these tell we started in on the overhead ones we build now.
Russ McCutcheon
www.mccutcheonmetalfabricationaviation.com
russmccutcheon@gmail.com
We build many of your RV weldments.
Old 06-02-2018, 07:14 PM
I'm certain that they'd be a lot different than the RV-6 ones that Van's designed, but the RV-3B kit uses floor-mounted pedals and brakes.
Old 06-03-2018, 10:25 AM
No, The RV-6 had floor mounted pedals, We are the ones that build the current overhead pedals and the past floor mounted pedals for Van's, I have all the fixtures and have even built some for Van's maybe 5 years ago and can still build any of it including the little brake pedal weldments he is looking for, just need the stampings and an order from Van's. So if you can't find them used call Van's, ask for Daryl S, he can probably get it figured out and ordered for you.
Russ McCutcheon
Old 06-03-2018, 10:25 PM
AMURRAY's Avatar
AMURRAY AMURRAY is offline
I have a pair of passenger side toe brakes. Straight from 1988. Never used. If you need them you can have them. Also have floor mounted pedals but they are pre SB 98-03-1. SB would need to be applied.
aaronjmurray at rocketmail dot com
[IMG]IMG_2348 by Aaron Murray, on Flickr[/IMG]
RV6 built and flying
Bearhawk Patrol plans purchased
Old 06-05-2018, 05:23 AM
Thanks to Lorne from Texas I’ve now got what I need. Thanks for everyone’s input. Greg
