Old 05-13-2018, 06:56 PM
Pounder Pounder is offline
Default Empennage
I suppose this info is already out there, but who is aware of a product (adhesive?) and application technique internal to rudder (and other empennage surfaces) to prevent oil canning or otherwise cracking?
Old 05-13-2018, 08:47 PM
Michael Henning Michael Henning is offline
RTV silicone between the skin stiffeners by the trailing edge.
Mike
RV-4 #2750
N654ML
IO-360
WW150C Prop
1018 lbs
Flying
Old 05-16-2018, 05:43 PM
smokyray's Avatar
smokyray smokyray is offline
Default Hy-Sol
Michael's technique works well.
Additionally:
Since I had .016 skins, I used Hy-Sol, a structural epoxy (used by Lancair and other composite/wood/metal builders to glue skins together) for additional strength and to fight cracking between rivets.
https://www.rshughes.com/p/Loctite-E...180516224238:s
I spread it thin between the stiffeners and skin prior to riveting. Working time is 40 min, cure 24hrs.
Excellent product, Grumman aircraft were assembled with a similar epoxy.
V/R
Smokey
PS:Side benefit is it holds everything in place and augments the rivets with impressive shear strength.
