  #31
Old 05-06-2018, 04:13 PM
polkaking27 polkaking27 is offline
okay, after reading the plans again it says to use a unibit... I suppose that answers my question right there. Using a unibit I obviously couldn't hit both holes from one side and end up with the correct size.
Old 05-06-2018, 04:24 PM
You’re drilling structural parts here. I’d call Vans and see if they’re okay with new 5/8” holes close to the old, incorrect ones. They might suggest a doubler or some other reinforcement.
Old 05-06-2018, 07:12 PM
Carl, You are absolutely correct. It appears that the original builder routed the rudder cables through the already existing holes and didn't drill any new holes in that area.
Bob- That being said, before I drill through a spar I feel more comfortable calling vans and talking to them about it. So I'm waiting until tomorrow to proceed with anything. Thanks for your concern. Hopefully Carl and I are correct and won't need any doublers or fixes, but we will see what they say!
Old 05-11-2018, 02:00 PM
I talked to Van’s this week and verified that the cables indeed were run incorrectly through the predrilled holes that are there for wiring (I believe). I can see how this was easily overlooked because I also wouldn’t want to drill a hole through that bulkhead if there was a predrilled hole in nearly the right position. Van’s verifies that I did indeed need to drill new holes as referenced in dwg 64 (thanks Carl) But anyway, you guys were all correct. I got the new holes drilled and the cables re-routed and hopefully my bag of bolts and grommets from aircraft spruce comes in today and I can get her all put back together.
Thanks so much for the help. Hopefully this thread can help someone else in the future!
Old 05-11-2018, 07:22 PM
jabarr jabarr is offline
Now for the mag issue!!!???
Old 05-11-2018, 10:35 PM
Yes... Now thats the next issue for this weekend!
