Old 05-03-2018, 09:53 AM
fl-mike's Avatar
fl-mike fl-mike is offline
I'm thinking Kydex
Mike W
Venice, FL
RV-6A. Mattituck TMX O-360, FP, GRT Sport EFIS
N164WM
N184WM reserved (RV-8)....tail kit done, slow-build wing done, slow-build fuselage started.
Old 05-03-2018, 10:51 AM
txaviator's Avatar
txaviator txaviator is offline
Default Simple ABS Vacuum-Forming
This is what we do for a living.....albeit on UTV accessories and not RV's. This looks like simple ABS with a slight hair-cell finish. ABS plastic sheet is readily available at most any plastic supply house across the nation. KYDEX resembles the ABS identically, and is a lot more fire / burn resistant. Like mentioned, you could make a simple male tool out of MDF or plywood (MDF ideally). Then create a simple vacuum form fixture, heat the material, and suck it down onto the mold. This would be much prettier than 3d printing, in my opinion. In other words, it would 'flow' better, being molded around a constructed tool.
Gary Robertson
Arlington, TX
RV-12 Built / Sold / Flying
Currently Flying: Cessna Skyhawk 172
Rebuilding a true barn find J-3 Cub
Old 05-03-2018, 02:55 PM
Scott Hersha Scott Hersha is offline
Check out the rear stick cover from Cleaveland Airtool (aluminum) - $75. You could roll your own, or save time with this.
https://static1.squarespace.com/stat...Order-Form.pdf
I have one of these that I ordered with my interior from DJ for my new RV8. It includes the stick boot. Should be able to make it fit an RV4. I havenít installed it yet (just did my first flight last week), but the trial fit is pretty close. Iíll have to add the cup holder if I want - available from any boat store.
SH
RV-8
Cincinnati, OH/KHAO
Old 05-03-2018, 03:05 PM
This is exactly what they did at Aero Commander for the singles when I was there - first job out of college.
Old 05-03-2018, 06:51 PM
868RM 868RM is offline
Default Console
Abbey at Flightline has one
Old 05-03-2018, 10:55 PM
VA Maule VA Maule is offline
cdeerinck Aircraft Spuce part #11-02054 it's ABS apparently HDPE is about the same stuff their both thermoplastics.
Maule MXT-7(daily flyer)
Lancer 235(partner)
Raidial RV-8R Ephanage Done, Wings Done, Fuselage on it's tall Grove gear & engine hung
Old 05-04-2018, 08:29 AM
DanH's Avatar
DanH DanH is offline
Kitplanes, 2014, at Maule Aircraft:
http://sekisui-spi.com/technical-res...ming-processes
http://sekisui-spi.com/technical-res...chnical-briefs
The kicker is the requirement to build a form, and the vacuum tables/frames/etc. The form alone could be used for a glass/epoxy part.
Or just build an aluminum cover:
Dan Horton
RV-8 SS
Barrett IO-390
