Old 05-02-2018, 06:17 PM
DeltaRomeo's Avatar
Your host.
Default Where can I get one of these?
...asking for a friend.
v/r,dr
doug reeves.
Organ donor card signed (use anything you need).
RV-6 flying since '02.
Old 05-02-2018, 09:31 PM
jefferts jefferts is offline
Default Mee Too
I like the looks of that, are they available or is it "roll your own?"
Old 05-02-2018, 10:53 PM
VA Maule VA Maule is offline
That looks like a roll your own product. I think it's made of HDPE plastic sheeting that's available from Aircraft Spruce, I made the glair shield, front cockpit interior cover panels and other interior items from this material for the Lanceair. It's fairly easy to work with by using cardboard templates with wood forming blocks and a heat gun sorta kinda like hydro-forming but using heat instead of pressure. As professional as the console looks, it might have been made using a vacuum mold oven.
Maule MXT-7(daily flyer)
Lancer 235(partner)
Raidial RV-8R Ephanage Done, Wings Done, Fuselage on it's tall Grove gear & engine hung
Old 05-03-2018, 12:40 AM
OkieDave OkieDave is offline
It looks like something designed to go in a car, with a hole cut out by hand for the stick, and probably another for the eyeball vent (with the edge concealed by the vent mechanism, so it looks better than the big hole).
Old 05-03-2018, 06:09 AM
Michael White's Avatar
Michael White Michael White is offline
I agree...the raggedness of the stick hole tells me it's a re-purposed car part. I have no clue as to which car, though.
Moose
VAF #136
N424LZ Reserved
Old 05-03-2018, 06:28 AM
Check with Geoff Combs---bet he has some ideas.
Tom
Ridgeland, SC
Old 05-03-2018, 06:29 AM
Marc Bourget Marc Bourget is offline
It's not black magic. I watched an industrial arts teacher, (Don Pridham, author of the GPU Conversion book), laminate some plywood, drill holes for a home-made vacuum table, and, with a canister vacuum, make a panel overlay for his Mooney M-20.
The ultimate trick was, allowing for the 1/8"/ft shrinkage as it cools.
Old 05-03-2018, 07:02 AM
rleffler's Avatar
rleffler rleffler is offline
Tom
I second giving Geoff a call. With his new printer, he can do just about anything. Especially if you grab Solidworks from EAA and supply him all the files. Or barter a little advertising space.........
Bob Leffler
N410BL - RV10 Flying
http://mykitlog.com/rleffler
Old 05-03-2018, 09:32 AM
Ron RV8's Avatar
Ron RV8 Ron RV8 is offline
Pretty easy to do in aluminum. Do a card stock stretch-out first... I took out the drink holder, too much chance of water bottle interference with the stick... Water bottle now lays forward of the cover, still accessible....
Ron Townson
Okanagan Valley BC, Canada
RV-8 Completed Dec 2013
Membership renewed Nov 25, 2018
Old 05-03-2018, 09:46 AM
cdeerinck's Avatar
cdeerinck cdeerinck is offline
Question
I searched Aircraft Spruce for this, and was unable to find it. Could you possibly provide a link, part#, or full description?
~Chuck
DG-800S Sailplane
QB RV-8 -- Working on the canopy and wiring
84CX Reserved
