Go Back   VAF Forums > Main > Safety
Old 05-03-2018, 07:18 AM
climberrn climberrn is offline
The type of aircraft and color identification makes a lot more sense at non towered airports. I have NEVER been able to read another tail number in flight. When entering and planning the pattern N123A doesnít tell me if they are flying a wide pattern at 120KTS or dropping in at 70. Big difference when following a trike or cub, and a fast glass or RV. How do you know if the call from N123A was the trike or Citation that you know are in the area??
Not debating the calls regulated at towered airports or talking to ATC. They always ask for type anyway.
Joel
N626JA
RV-7A at CXP
Flying!
Old 05-03-2018, 09:00 AM
Mark H's Avatar
Mark H Mark H is offline
Originally Posted by Jesse View Post
It should be in your Operating Limitations, which make your airworthiness valid, so the must be followed.
The only relevant statement in my Operating Limitations is item 7. It reads:
"When filing a flight plan, the experimental nature of this aircraft must be listed in the remarks section."
There is actually nothing in my Operating Limitations about radio use. I know it used to be included as Scott eluded. My certificate was issued in October. Are my Operating Limitations unique? Does this mean the FAA is subtly changing their opinion on this as it pertains to towered controlled airports?
It is clear the FAA and FCC want us to identify type and N-number of aircraft. If I choose to drive 45 when the speed limit is posted 40, then all can I say when the officer pulls me over is "guilty". I know the law, even if choose not to follow it. The use of the word "Experimental" when making a radio call is much less clear to me.
Mark Hansen
Indianapolis, IN
RV-7A N896PS
Flying
Old 05-03-2018, 09:20 AM
Sam Buchanan's Avatar
been here awhile
The Op Lims for my 1999 RV-6 has the comment about including "experimental" in the initial radio call to a control tower.
The Op Lims for my 2016 Fokker replica does not have that comment but does state that "experimental" is to be noted in flight plans.
So yes, the FAA's stance on this matter has changed over the years.
Sam Buchanan
1999 RV-6
1918 Fokker D.VII replica
Old 05-03-2018, 09:56 AM
Low Pass's Avatar
Low Pass Low Pass is offline
Thinking back on the decades of flying at non-towered fields, I only identify an N-number called over the radio with a plane when it's someone I know very well. The rest of the time, all I hear is, "Anytown traffic, Piper blah-blah-blah-blah-blah-blah, left base, runway 14, Anytown." More than one Piper - which occurs fairly often - and I just don't keep up with the different planes by N-number. Sometimes I can keep up with the different voices, but when a second pilot/cfi calls out, that tosses out that differentiation.
What would be better is to simply say, "Anytown traffic, Piper turning base, runway 14, Anytown." Or, "...blue and white piper turning base."
Bryan
Houston
Old 05-03-2018, 10:40 AM
tomkk's Avatar
tomkk tomkk is offline
To tell the honest truth, it probably doesn't matter. I use the color & type with my radio calls too but it doesn't take much distance before we lose the ability to distinguish colors so my "red RV" probably just looks black to most others in the area if they can see me at all.
Tom
Port Orange, Fl
RV-12 N121TK ELSA #120845; first flight 06/10/2015
RV-12 N918EN ELSA #120995 Eagles Nest Project
SPA Panther N26TK in progress
Old 05-03-2018, 11:28 AM
fl-mike's Avatar
fl-mike fl-mike is offline
I got in the habit of saying "Experimental RV" since someone pointed out years ago that "RV" sounds a lot like "Army".
I also subscribe to the color call out as it gives me a better chance of being differentiated from the other RV's or low wings. When there are more than one Cessna in the pattern I am always fearful I'm looking at the wrong one and the other might be right above/below me, as the students are always just using the N-number.
Mike W
Venice, FL
RV-6A. Mattituck TMX O-360, FP, GRT Sport EFIS
N164WM
N184WM reserved (RV-8)....tail kit done, slow-build wing done, slow-build fuselage started.
Old 05-03-2018, 05:09 PM
Bicyclops Bicyclops is offline
And...folks often seem to report what they see way out in front of them as their current position. Sometimes makes them really hard to find. I was trying to figure out one time, where the Bonanza was who I had heard reporting downwind and final. I called and asked him where he was and he reported 5 mile final. This was at an airport with a 600' AGL pattern altitude, normally flown very close in for terrain clearance.
Then there was the guy that tried to kill me flying the opposite pattern, NORDO. You haven't lived until you've done a full flap go-around, 2 up, in a C-150 at about 10000' density altitude starting about 20 feet from landing on an idiot. "Radio isn't required at a non-towered airport", he said when I tracked him down at the FBO. Also, "How was I supposed to know it isn't left traffic here?"
Ed Holyoke
Old 05-03-2018, 09:06 PM
dabney dabney is offline
Default Anti-authority?
Isn't the objective of giving position reports at non-towered airports to avoid a mid-air collision?? Giving your N number is of little value in accomplishing that. Giving the type of plane and color gives other aircraft in the vicinity of the airport a chance to identify your aircraft from other Cessnas or RV's etc.
Call that anti-authority if you must, but it may prevent a mid-air
Also, the only thing worst than no position report is an inaccurate position report. Most of the "uncomfortable proximity" situations I have experienced occurred when I was searching the sky where a pilot said he was only to find out later that he was someplace else. At least with no position report you are scanning the entire area for traffic and your scan is not diverted to the wrong place.
I do concur with the post that views that disagree with the AC should be passed along to the FAA for what that is worth.
Paid for 2019 and well worth it!
Best investment I make all year....
US Army 1st Cavalry Division OH-58 AO
LAPD helicopter pilot, retired
RV6A, RV12 (non-builder)
Old 05-03-2018, 09:34 PM
catmandu's Avatar
catmandu catmandu is offline
Dabney, you are spot on.
And forgive me, 'Anti-authority attitude' is a pet peeve, I tried to relay my sarcasm with the roll eyes, but the limitations and lamentations of this here interwebs makes it hard to do so (Google 'Anti-authority attitude' and you will be hard pressed to find any reference to this 'thing' outside of the FAA).
Personally, all I try to do is build a picture in my mind when I am at an uncontrolled field. I could care less what one calls oneself, as long as one is consistent in said calls and does a reasonable job of reporting one's position. I'll figure out the relative speeds on my own, based on the calls. Extras like saying "Cub" and "Meridian" versus "Piper" do help build that picture.
My failing eyeballs have problems just spotting airplanes, let alone identifying airplanes. I rely more on the mental situational awareness than anything.
I tend towards "Experimental 28RV" hoping the "RV" gives others awareness. Still a tough call, as the home field has a bunch of -12's, so the "RV" tag could be as much as a 30 KIAS difference in pattern speeds. The -12's do tend to use "Light Sport" in their calls, so that helps.
Mike C.
Maryland's Eastern Shore
stuck in 1/5th of an Arrow, my partners won't let me go
RV-6A bought flying
Old 05-04-2018, 05:43 AM
spatsch spatsch is offline
Totally agree. I donít find color particularly useful and aircraft type marginally useful ( knowing itís a single engine low wing helps, listening to an exotic airplane type doesnít ).
What I do find useful in my RV is my ADS-B. Makes me spot airplanes at least a mile sooner as I know precisely where to look ( I know where somebody 5 miles NE actually is not where he thinks he is .....) and it allows me to sequence myself into the approach based on the progress I see the other make relative to me way before I can see them visually.
You do still have to worry about NORAD and no transponder airplanes ( have one my self ) but ADS-B clearly improves the safety at non towered airports.
Oliver
Oliver Spatscheck
RV-8 & J-3
N-2EQ & NC-49762
http://www.spatscheck.com/oliver
