Old 04-30-2018, 01:52 PM
cdeerinck's Avatar
cdeerinck cdeerinck is offline
Question Mid Cabin Cover question
My in-process RV-8 is in need of a single 3 1/8" Instrument in the location of my Mid Cabin Cover. It is a fuel injection controller, and not typically required during flight, so I am ok with the lower location. (and I have zero panel space available)
There are 3 ways to solve this that I can think of:
  1. Take part F-880C-R-1 (Mid Cabin Cover on drawing 68A) from an RV-8A, and cut down the aft portion, and fit it on an RV-8.
  2. Design and make a similar part to the F-880C-R-1 myself. If I do this, I would probably rotate the face of the instrument about 30 degrees toward the pilot.
  3. Construct an angled "box" that would sit on top of the existing part F-881-1 (Drawing 68) with a hole for the rear of the instrument.
My questions for this group:
  1. RV-8 Builders: Has anyone done something similar to #1 above?
  2. RV-8A Builders: Can anyone tell me the dimensions of the rear angled face of F-880C-R-1? If it isn't at least 3.8" it won't work for my application.
Here is a very rough mock-up.
or here if that link doesn't work: http://tinypic.com/m/k51iko/4
~Chuck
DG-800S Sailplane
QB RV-8 -- Working on the canopy and wiring
84CX Reserved
Old 04-30-2018, 02:06 PM
sjhurlbut sjhurlbut is offline
Default Covers
I did something very similar to this. Mounted fuel gauge above fuel selector at an angle. I ordered a new 881PP cover since the fuel valve was already installed and need to be redone. I looked at 8A plans as well and ordered:
F-8113A-L-1 mid cover and cut it down
F-8113-B-R-1 and F-8113-B-L-1 side covers. I did reinforce the front plate with 0.063 for an instrument.
Can send pics if you want.
"Aerodynamics is for people who can't build engines"
Enzo Ferrari
Steve H
Cold Lake, Alberta
RV7A #70015 - C-FZQX - built - sold
RV7A #71629 - C-FSIS - built - sold across Atlantic
RV7 #70215 - C-GOJU - flying - sold
RV7 #70703 - C-GMIY - flying - sold
RV6 #60119 - C-FHBZ - built - Airventure 2016 Bronze Lindy - sold
RV10 #41779 - built emp - sold
RV8 #82842 - C-FSBG - Fastback with big hp IO-360-A1B6 10:1
Old 04-30-2018, 02:13 PM
mill2978's Avatar
mill2978 mill2978 is offline
Default Fiberglass
I made something similar on the left side FWD of the fuel selector switch. I made it out of fiberglass. I started with cardboard cutouts, then used those to make a mold out of pink foam. Glass makes it real easy to get the angle/position you want.
Aaron Miller
RV8 N127KT - First Flight October 16, 2018
http://www.mykitlog.com/AaronMiller/
Old 04-30-2018, 02:43 PM
cdeerinck's Avatar
Steve - Pictures would be fantastic. Can you email them to me at cjd9 @ me.com ?
~Chuck
DG-800S Sailplane
84CX Reserved
Old 04-30-2018, 02:46 PM
cdeerinck's Avatar
Aaron - Would you happen to have any pictures of either the process, or final result? I'd love to see them.
~Chuck
DG-800S Sailplane
84CX Reserved
Old 04-30-2018, 03:50 PM
mill2978's Avatar
PM sent, send me your email and I'll share them with you.
Aaron Miller
Old 05-02-2018, 09:38 AM
Default Fuel pic
Here is mine. Might not work for you as the instrument penetrates the 881 cover.
Enzo Ferrari
Steve H
Cold Lake, Alberta
