Old 04-20-2018, 07:20 PM
Djgeib Djgeib is offline
Default Flap blocks
Getting close to drilling holes in the nylon flap blocks. Was wondering if standard drill bits are ok or if I should use plexiglass bits?
On the positive side completed my rotisserie today.
https://douglasgeib.smugmug.com/N104MG/i-Fq2p6zd
https://douglasgeib.smugmug.com/N104MG/i-TPs8Dqd
Doug Geib
KFHB
RV8 empennage complete
QB wings started
Old 04-20-2018, 08:03 PM
daveyator daveyator is offline
Normal drill bit is all you need to use. Keep good control using a drill press,and clamp the work firmly, as the drill will want to pull into the plastic as soon as it starts to cut.
DaveH
120485
Old 04-20-2018, 08:31 PM
nzrv8's Avatar
nzrv8 nzrv8 is offline
Also, it helps to drill slowly or the drill bit can wander slightly while moving through the material. Using a short drill bit helps too. If the exit holes are even slightly off centre compared to the entry holes, then getting the blocks to bolt up can be a pain due to the bolts not quite being square to the blocks/floor/support angle/nutplate sandwich.
I ended up using a lathe and a drill stock for mine, I just couldn't quite get it right using a drill press.
Paid up - Dec 2018
Old 04-25-2018, 08:07 PM
I was able to successfully drill the flap blocks on the drill press. It was surprisingly easy. I did drill slowly and at a slow speed. Now I have another problem. Clearance for the bolt head and the aft seat belt bracket is not sufficient. After talking to the mother ship, I will remove the seat belt brackets and take about 1/32 off their leading edge to allow the bolt head clearance to tighten down all the way.
https://douglasgeib.smugmug.com/N104MG/i-QXMkSJk
Doug Geib
KFHB
QB wings started
Old 04-25-2018, 10:15 PM
VA Maule VA Maule is offline
Use a wood drilling spade /paddle bit @about 5/8" and counterbore for the depth of the bolt head.
Maule MXT-7(daily flyer)
Lancer 235(partner)
Raidial RV-8R Ephanage Done, Wings Done, Fuselage on it's tall Grove gear & engine hung
Old 04-26-2018, 01:43 AM
xblueh2o xblueh2o is offline
I had the same problem. I too took a little off after exchanging emails with Van's. I used a carbide burr and took a slight scallop out of the bracket with enough room to allow a socket wrench to get on the head of the nut.
Sam
RV-8 with the Showplanes Fastback conversion
Emp completed except for glass work
Wings completed except for bottom skin and glass work
Fuselage underway
N18451 reserved
