Old 04-17-2018, 10:59 AM
JwWright57 JwWright57 is offline
Default Deburring spars
Hi all
I've read in the forum that I shouldn't touch the wing spars just use them as is. But man are they a little rough! Sharp edges, tooling steps, etc. Vans guidance in section 5 is to file the edges on everything to remove the tooling marks, why doesn't the spars need this done?
Also, what about the aluminum angles (for rib attachment) that are pre-riveted to the spar? Their edges are pretty rough also, are they fair game for a little SB wheel or file?
Jeff Wright, Charlotte NC
Rv-12 started!
Tail 99% done
Wings 99% done
Waiting for fuse kit, should be here in a few weeks!!
Dues paid 2019
Old 04-17-2018, 03:50 PM
mike newall's Avatar
Good point, well made.
One of our spar 'leaves' stands proud and is giving an issue with pin fit. The spar goes deep enough, but the bush just sits a RCH low due to one leaf being a little high. I will wait for Scott's input
Donated in 2018
Old 04-17-2018, 04:48 PM
Originally Posted by mike newall View Post
sits a RCH low
I think that may be a first for VAF...
Hinckley, Ohio
EAA #499867
RV-12 E-LSA #120058 AWC Jul 2012 - Bought Flying Oct 2015 with 48TT - Hobbs now 406
LSRM-A Certificate 2016
Special Thanks to EJ Trucks
Old 04-18-2018, 12:07 AM
rk2436 rk2436 is offline
The official response has been to leave them alone and use as is. I couldn't live looking at those rough edges on the spars visible in the cockpit. So I took the vixen and smoothed that section out. Nothing you can do about all the spar caps further outboard,probably do more harm than good. Yeah, I know I knocked off the anodizing or primer but a wipe every once in a while keeps them looking nice. Keep at it,it's an awesome flying plane!!
Old 04-18-2018, 02:26 AM
az_gila's Avatar
az_gila az_gila is offline
Exclamation
Nah, it's a common engineering term...
http://www.vansairforce.com/communit...14&postcount=3
OK looking at post#2, it maybe with somewhat of a UK origin... B. Eng., University of Liverpool, 1968
An even smaller unit of measurement would refer to the male reproductive organ of a gnat.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 04-18-2018, 12:30 PM
rv9builder rv9builder is offline
Originally Posted by JwWright57 View Post
Hi all
I had the same question about the parts in the pre-built fuselage center section. Tech support told me the anodized parts were OK to use in the condition we received them.
Having read Section 5, I was surprised at their answer. While the center section parts weren’t likely to draw blood, I could certainly feel roughness. Perhaps many of us (including me) have been making the edges of parts a lot smoother than they need to be.
RV-12iS Fuselage
RV-9A Project: Sold
VAF donation made for 2018
Old 04-27-2018, 04:13 PM
AeroDog AeroDog is offline
I first encountered that unit of measure during my first year as an engineering student back when dinosaurs roamed the earth. I didn't realize that it is also used on the other side of the pond.
Jerre
Empennage, fuselage and wing kits complete
Finish kit nearly complete
RV-12 120593 N42KJ reserved
http://webpages.uncc.edu/~hill
http://jerre-hill.blogspot.com
=VAF= dues paid 2018
Old 04-27-2018, 08:45 PM
Defined in my Navy Nuke days as the finest discernible adjustment possible!😜
Old 04-27-2018, 08:53 PM
As our learned correspondent alluded to, it is oft referred to over here as a GCH, which indeed, as a cross section dimension is a very tiny measure, slung under an insect and probably flying in the wind....
I used the Americanised version to enable Colonial colleagues to acknowledge the minute amount involved.....
Donated in 2018
Old 04-28-2018, 08:42 PM
FORMER colony! —- We won fair and square!😝
