  #151
Old 04-26-2018, 09:35 PM
PMLviator PMLviator is offline
Unhappy washer wrench
Doug
Can you describe or explain your " washer wrench"?
Old 04-27-2018, 01:08 AM
Gagarin737's Avatar
Gagarin737 Gagarin737 is offline
Originally Posted by PMLviator View Post
Doug
Cleaveland Aircraft Tool $37
PH-BZT
MyKitlog
Picasa pictures
Old 04-27-2018, 07:43 AM
DaleB's Avatar
DaleB DaleB is offline
Originally Posted by Gagarin737 View Post
And worth every penny when you need them.
Dale
Omaha, NE
Previous RV-7 project (sold)
Old 04-27-2018, 06:30 PM
Thanks Joeri, it"s on order
Old 04-27-2018, 07:39 PM
I have had some success putting a magnet on the bolt head after partial insertion and getting the washer to stay put on the bolt shank. This job needs all the tricks!
Old 04-28-2018, 02:19 AM
HansLab HansLab is offline
Default Wrench
Yes, thanks for the pic, Joeri. It's on the projects-to-make-before-I-start-on-SB list.
Hans Labruyere
build & sold project Kitfox IV
Bought project & building RV12 #120742
Old 05-03-2018, 12:16 PM
Gagarin737's Avatar
I installed the stabilator today. After glueing the washers with super glue I embedded the washers with epoxy. No problem with knocking off the washers. Still took some time to insert the bolts.
PH-BZT
MyKitlog
Picasa pictures
Old 05-19-2018, 06:57 AM
joedallas's Avatar
joedallas joedallas is offline
I did not want the HS-01231C on top of the skin of the Stabilator.
I am doing a vinyl wrap and I have all CS4-X Rivets to keep the vinyl as flat as possible.
This is not a recommendation
Also this is not a cracked Spar repair.
See More
http://joesrv12.com/Builder%20Log/SB_18_02_02_01.htm
Joe Dallas
Joe Dallas
Kit-#12400
www.joesrv12.com
www.EAA1298.com
Old 05-19-2018, 08:44 AM
See More
Joe Dallas
The full sized doubler was not designed specifically to a repair stabilators that were found to have cracks.
It was specifically designed based on doing an FEA (finite element analysis using a computer model), and analyzing the loads seen in the hinge joint / fwd spar.
My recommendation to other builders is that they install the parts as designed.
There will be no problem applying vinyl over the doubler (if that is your plan) after some experience is gained working with the wrap material.
Scott McDaniels
Hubbard, Oregon
Old 05-19-2018, 11:10 AM
joedallas's Avatar
Default My View
Scott
I made it perfectly clear that this is not a recommendation.
We have different views on what a patch looks like.
I can install vinyl over LP4 Rivets and with a lot of finger time they look ok.
I think it looks better over CS4 Rivets.
And Vinyl over a Patch Still Looks Like A Patch in my view.
We also designed a lot of things before Computers were invented.
I sure if you ran a computer analysis on my design it would stack up pretty well with Van's and a lot better than Vans original design, and with only few problems worked pretty well.
However that is not the point, I am building EAB so I can have the Aircraft I want not a standard RV12 which is a well built Aircraft.
It is a good thing that Van used his own ideas to built all the great Aircraft in his line.
Thanks for your View
Joe Dallas
Kit-#12400
www.joesrv12.com
www.EAA1298.com
