Old 07-17-2017, 03:46 PM
Azjulian Azjulian is offline
All you need to do is put that file into the "garmin" folder on your SD that you use in your display and it will be made available.
Old 07-17-2017, 06:30 PM
rjtjrt rjtjrt is offline
Thanks Julian, much appreciated.
John
Old 07-19-2017, 06:45 PM
backcountry backcountry is offline
Thank you for sharing
Old 05-02-2018, 10:16 AM
hudgin hudgin is offline
Ok I have the check list written and edited how I want it but I can't get it to go onto my G3X. I guess I need step by step detailed instructions than just put it on a SD card and install it. It doesn't work. The G3X doesn't even acknowledge it.
member 1 of 6
Metal Feathers Club
RV 7 N706CB
1st flight Oct 18, 08
S/N 72847 tip 200HP CS glass IFR
Old 05-06-2018, 10:01 AM
rongawer rongawer is offline
I have my checklist “N975G_Checklist.ace” file, saved to the root folder of my SD card, which I keep in the PFD. On startup, the G3X reads the file and makes it available for the checklist tab. Works well for me.
Assuming you have saved the .ace file from the checklist editor, just save it in the root folder of a compatible SD card and insert into the G3X. When started up, the G3X will have a checklist screen available.
Ron Gawer
- RV10, N1530G (reserved). Empennage in progress.
- RV12, N975G, "The Commuter"
