Go Back   VAF Forums > Avionics / Interiors / Fiberglass > Electrical Systems
View Poll Results: On your current airplane, how reliable is/was your alternator
I have used an automotive alternator and had no failures in its first 250 hours. 111 25.87%
I have used an automotive alternator that failed within the first 250 hours. 24 5.59%
I have used a Plane Power alternator and had no failures in its first 250 hours. 133 31.00%
I have used a Plane Power alternator that failed within the first 250 hours. 51 11.89%
I have used a B&C alternator and had no failures in its first 250 hours. 107 24.94%
I have used a B&C that failed within the first 250 hours. 3 0.70%
Voters: 429. You may not vote on this poll
  #121
Old 05-16-2018, 04:59 PM
Originally Posted by RV10inOz View Post
I have just had my second failure at around 900 odd hours and now at 1380, so not even 500 on the last one.
VPX starts shutting things down, so one wonders what the high frequency spikes are damaging along the way.
Two failures on which brand/type?
Old 05-16-2018, 08:43 PM
jeffw@sc47's Avatar
jeffw@sc47 jeffw@sc47 is offline
Default Mantra or Pixie Dust?
Good poll Steve. B&C (alt and reg) working flawlessly after first 2,500 hours. Standard installation no cooling hose and still on original belt. Bought new in 2007, flying since 2011.
Vlad, you need to document what you do special with your alternator so we can get the same endurance, especially with belt.
Jeff Warren
Simpsonville, SC (SC47 - 10nm NW Triple Tree, SC00)
1946 Bellanca Cruisair 14-13-2 (72 YRS OLD 8/15/18)
RV14A (N14ZT), Ser#140195
Start 10/11/14
Dues paid 12/2/18 (USArmy 2/67-2/70)
www.mykitlog.com/jeffw@sc47
!! I SURVIVED RIPON ARRIVAL - KOSH 7/21/2018 !!
Old 05-17-2018, 06:16 AM
RV10inOz's Avatar
RV10inOz RV10inOz is offline
Sorry, I thought it was assumed as a plane power.
Not happy.
______________________________
David Brown
DYNON Authorised Dealer and Installer
The two best investments you can make, by any financial test, an EMS and APS!
Old 05-17-2018, 10:04 AM
catmandu's Avatar
catmandu catmandu is offline
I voted way back when, made it past 250 hours with my 50 amp automotive, but it failed this month after just over 300 hours (internal voltage regulator failure). But, per the plan, I was able to go to NAPA the next morning when they opened at 7am and get a replacement for free (lifetime warranty) that actually works better than the first one per the test label on it (and no more low voltage warnings at idle).
Mike C.
Maryland's Eastern Shore
stuck in 1/5th of an Arrow, my partners won't let me go
RV-6A bought flying
Old 05-17-2018, 10:36 PM
svyolo svyolo is offline
The couple of local places that "rebuild" alternators locally are getting a bad rep as the voltage regulators they use are failing quickly.
They both claim that they are buying the only available regulators. Myself, and a couple of colleagues that still are in the automotive business all say you can never trust any of the rebuilt alternators, starters, PS pumps from any of the big retailers. You might get lucky, but on an airplane?
Old 05-18-2018, 07:06 AM
rv6ejguy's Avatar
rv6ejguy rv6ejguy is offline
Totally agree. Unless you go right to Denso for a rebuilt (I listed a source here before), you'll usually get El Cheapo offshore regulators which are at the center of most failures. One of the popular EXP aircraft brands doesn't use OE Denso parts either and look at the failure rates in this poll.
Turbo Subaru EJ22, SDS EFI, Marcotte M-300, IVO, RV6A C-GVZX flying from CYBW since 2003- 427.8 hrs. on the Hobbs,
RV10 95% built- Sold 2016
http://sdsefi.com/cpi.htm
Old 05-18-2018, 08:00 AM
DanH's Avatar
DanH DanH is offline
The popular Plane Power 60 amp appears to be a custom version of this unit....
https://www.unipoint.com.tw/product_...e.php?p_id=508
...with its #662 regulator modified by the addition of a jumper (Unipoint part number 6621).
Unipoint is a Chinese division of Bosch.
http://www.bosch-aa.com.cn/en/intern...ss_011211.html
Dan Horton
RV-8 SS
Barrett IO-390
Old 05-18-2018, 01:25 PM
twsurveyor's Avatar
twsurveyor twsurveyor is offline
Default 60 amp Van’s internal regulated alternator!
Originally Posted by bhester View Post
I have a Van's 60amp internal regulated alternator that is my original Feb. 2007 alternator. 850 hrs and still going. No blast tube.
Ditto here Bobby, 830 hours with blast tube! 👍🏻
Tommy Walker
Ridgetop, TN (1M5)
RV-6A, N 350 TW
830 Hrs & "Climbing”!
Old 05-18-2018, 05:53 PM
RV10inOz's Avatar
830 hours....I will check my logs today, but I think it is time you purchased a spare.
just sayin'
David Brown
Old 05-19-2018, 12:49 AM
SHIPCHIEF SHIPCHIEF is online now
I have a 40A Denso mini that has 160 hours. It had an early failure: The plastic Brush boxes were warped and stuck the brushes so eventually they lost contact with the com rings. a few bux for a new piece of plastic, and the alternator has been flawless.
But!! Van's light weight alternator bracket for Narrow Deck cases was too light, it cracked and had to be replaced with a heavier Lycoming part. Might be some balance issue, or the Gates brand belt might be uneven...?
Keeping the weight down and the reliability up is a challenge.
Scott Emery
http://gallery.eaa326.org/v/members/semery/
EAA 668340, chapter 326 & IAC chapter 67
RV-8 N89SE first flight 12/26/2013
Yak55M, and the wife has an RV-4
There is nothing-absolute nothing-half so much worth doing as simply messing around with Aeroplanes
(with apologies to Ratty)
2019
