Old 12-04-2015, 05:28 PM
Dvalcik's Avatar
Dvalcik Dvalcik is offline
Dave, No still on the cruise with the Rubin's. We will have a VAF hat sighting at the Panama Canal soon!
David
EAA 1434 KBST
Belfast, ME
david@rv12pilot.com
2019 VAF Supporter
RV12 #568 EAB
* Started 9/30/2011
* 1st flight 8/30/12
http://www.rv12pilot.com
Old 05-13-2018, 06:54 PM
Default Seal Fuselage Spar Openings…
I removed my wings last week while performing an inspection and remembered a post about adding foam rubber to the root rib in order to seal the fuselage spar opening. So I cut foam 1.5” wide and thick enough to protrude ½” beyond the edge of the wing skin. Foam pieces are full height of the root rib. One piece of foam on each side of the spar is held in place with double-side tape against the root rib. When the wing is slid in place the foam rubber compresses by ½” and seals the spar cutout in the fuselage. Full test will be next winter but reduction in airflow in the cabin is very noticeable. I think this is going to work a charm...
Hinckley, Ohio
EAA #499867
RV-12 E-LSA #120058 AWC Jul 2012 - Bought Flying Oct 2015 with 48TT - Hobbs now 406
LSRM-A Certificate 2016
Special Thanks to EJ Trucks
Old 05-13-2018, 08:26 PM
tomkk's Avatar
tomkk tomkk is offline
I'll be real interested in how that works out. I tried something similar with weather stripping and it didn't have much of an effect.
Tom
Port Orange, Fl
RV-12 N121TK ELSA #120845; first flight 06/10/2015
RV-12 N918EN ELSA #120995 Eagles Nest Project
SPA Panther N26TK in progress
Old 05-13-2018, 08:30 PM
Tom
You live in Florida. Maybe wrong approach for you. Try installing add'l vents...
Hinckley, Ohio
EAA #499867
Old 05-14-2018, 05:59 AM
tomkk's Avatar
Oh, don't need it at all while down here. Up north in November or so, another story ...
Tom
Port Orange, Fl
Old 05-14-2018, 08:48 PM
Handclutch Handclutch is offline
Somebody asked me for a photo quite some time ago. Had the wings off earlier in the year, took a pic and then didn't get around to posting. Was still working out how to upload photos - think I've cracked now, or at least I hope so! These seals work a treat.
Jack
Old 05-14-2018, 09:31 PM
DaleB's Avatar
DaleB DaleB is offline
Nice! Thanks for posting that. It’s about time to commence the condition inspection on ours. Perfect time to stick in some foam blocks.
Dale
Omaha, NE
Previous RV-7 project (sold)
Old 05-15-2018, 09:37 AM
DHeal DHeal is offline
I would suggest that the aluminum surfaces underlying any such foam blocks be coated with corrosion-resistant paint -- as it appears Jack above (or is it down-under?) has done. Over a period of time, the foam has the potential to entrap and hold moisture against the aluminum leading to possible corrosion.
RV-12 E-LSA #120496 (SV w/ AP and ADS-B) - N124DH flying since March 2014 - 710+ hours (as of Dec 2018)!
VAF donation through June 2019.
Old 05-15-2018, 10:09 AM
DaleB's Avatar
If there is one thing my airplane is not short of, it's paint. Trust me.
Dale
Omaha, NE
Old 05-15-2018, 05:02 PM
Can’t take the credit for the paint - I didn’t build it. The guy did protect the airframe very well. It was his third RV and he certainly knew what he was doing by the time he got to the this one - I’m the beneficiary of great workmanship!
Jack
