Old 08-29-2013, 01:02 PM
dhauck dhauck is offline
As a slight side note...an interesting article related to the strength of powder coated aluminum.
http://digitalcommons.lmu.edu/cgi/vi...ntext=mech_fac
Old 08-29-2013, 01:37 PM
WenEng WenEng is offline
Default Thanks for adding fact to our regular hanger talk...
Jump to the end to see that powder coating did not affect 2024 or 6061, especially at lower temp single bake..... I read somewhere you need to heat at 350F for 5 hours to get to T6.
That's ok though. There are plenty other misconceptions to keep the fires burning. Lets talk lean of peak....
Wendell VAF#1832
RV-6A 3/4 done...N48JE Reserved
Build site: www.mykitlog.com/weneng
Donated to VAF in 2018
Old 08-29-2013, 03:11 PM
txaviator's Avatar
txaviator txaviator is offline
Or, talk about primer
Gary Robertson
Arlington, TX
RV-12 Built / Sold / Flying
Currently Flying: Cessna Skyhawk 172
Rebuilding a true barn find J-3 Cub
Old 05-09-2018, 08:21 AM
jpflys1 jpflys1 is offline
Has anyone powder coated the flap handle? Concerned if the heat affected the bearing.
Old 05-09-2018, 09:07 AM
I put heat shrink tubing on my flap handle. Color is red to match seat inserts. Heat shrink is very durable and doesn't chip like paint when inside seatbelt buckles get thrown into void between the seats...
Hinckley, Ohio
EAA #499867
RV-12 E-LSA #120058 AWC Jul 2012 - Bought Flying Oct 2015 with 48TT - Hobbs now 406
LSRM-A Certificate 2016
Special Thanks to EJ Trucks
Old 05-09-2018, 09:27 AM
This is the reason that it is supplied un-powder coated and intended to be painted by traditional methods.
At the very least, all of the lube grease will have been baked out of it, potentially making a mess of the powder coat finish.
Scott McDaniels
Hubbard, Oregon
Old 05-09-2018, 11:40 AM
Thanks scott
Old 05-09-2018, 12:11 PM
videobobk's Avatar
videobobk videobobk is offline
I am having two RV-12 panels powder coated this week. We have had one done in the past, and it looks great, two coat flat grey. The company told me I would be happier with the 2-coat process, first for color and 2nd for removing the shine. The first one really looks good and held up well. We are trying the flap handle on one also--will report results. The plant manager seems to think it will do fine and he has over 40 years experience, so worth a shot.
Bob
Bob Kelly, Scipio, Indiana
Tech Counselor
Founder, Eagle's Nest Projects
President, AviationNation, Inc
RV-9A N908BL, Flying
Old 05-09-2018, 01:23 PM
scottmillhouse's Avatar
scottmillhouse scottmillhouse is offline
About what does it cost to powder coat a panel?
Scott- 2019 dues paid
Got medical back, now building a 7A; N579RV reserved, new engine installed, doing FWF, instruments & finish painting.
RV-12 #120515, N319RV 1st flight 12/2015 now over 280 hours.
RV-9A, 536 hours sold, RV-7 sold, Kitfox sold
Old 05-09-2018, 04:15 PM
DHeal DHeal is offline
If powder-coating or covering the panel with vinyl overlay be sure to heed the plan's instructions and file the panel edges to permit the extra clearances required to accommodate the extra film thickness -- you are forewarned!
RV-12 E-LSA #120496 (SV w/ AP and ADS-B) - N124DH flying since March 2014 - 710+ hours (as of Dec 2018)!
VAF donation through June 2019.
