Old 08-28-2013, 01:02 PM
WayneJ WayneJ is offline
Default Powder Coating
Has anyone powder coated interior parts? I am planning to paint all the visible interior parts not covered with upholstery but thought powder coat might be a good option.
Wayne
Auburn, WA
120642
Old 08-28-2013, 02:50 PM
Rupester Rupester is offline
Default Panel ...
I powder coated the panel with a satin finish, color to match the exposed metal parts of the interior. I wanted durability and cleanability. It provides exactly that.
Terry Ruprecht
RV-9A Tip-up; IO-320 D2A
S. James cowl/plenum
(Dues paid thru Nov '18)
Old 08-28-2013, 04:01 PM
Catbird Catbird is offline
I also powder coated my instrument panel with a beautiful satin black finish. However...you may want to reconsider powdercoating any interior parts that provide structural integrity to the airframe. The powder coating process requires heating the metal part to temperatures that may compromise the heat treat the of aluminum, thereby reducing the physical properties such as yield strength, tensile strength, shear strength, ductility, and resistance to stress cracking.
Old 08-28-2013, 07:02 PM
Michael Henning Michael Henning is offline
I powder coated all of the steel parts inside of fuselage.
Mike
RV-4 #2750
N654ML
IO-360
WW150C Prop
1018 lbs
Flying
Old 08-28-2013, 07:09 PM
N223JH N223JH is offline
Powdercoated the panel. Our facility had a limited number of color choices so you may want to get samples of the interior fabrics to make sure of getting a non-clashing panel color. As you probably know, females have a better eye for complementary colors and this kind of advice-seeking adds to her "ownership" of the build. Always a good thing.
Jim
RV-12
Old 08-28-2013, 07:30 PM
rjtjrt rjtjrt is offline
This is important advice - powder coating significantly affects structure of metal and this is an imprtant consideration if part is structural.
Old 08-28-2013, 09:47 PM
DaAV8R DaAV8R is offline
I spent the afternoon with a powder coater. The companies that I work with can generally get any of the colors on RAL color chart. A quick google search will find the chart. They can also match colors but I expect the cost might be too much for the small quantities we would generally need.
Robert Williams
Lee's Summit, MO
RV-8 - Empennage & Wings Done
Working on Fuse
O-360-A1A
1946 Cessna 120
Old 08-29-2013, 11:21 AM
I learned the powder cure temperature is 400F for 20-22 minutes. Could that damage 6061-T6 or 2024-T3? I'm concerned about both distortion and metallurgical damage.
Wayne
Auburn, WA
120642
Old 08-29-2013, 11:26 AM
rocketbob's Avatar
rocketbob rocketbob is offline
400 degrees doesn't hurt aluminum parts. I have a cheap HF powdercoat gun and it works marvelously ($38 with a coupon). I just redid the yokes in my C150.
400 degrees in the oven for 5-10 minutes is all it usually takes.
Bob Japundza CFI A&PIA
N55BC RV-6 borrowed, flying
N678X F1 Rocket, under const.
N244BJ RV-6 "victim of SNF tornado" 1200+ hrs, rebuilding
N8155F C150 flying
N7925P PA-24-250 Comanche, restoring
Not a thing I own is stock.
Old 08-29-2013, 12:38 PM
brianwallis's Avatar
brianwallis brianwallis is offline
VAF moderator
Default Powder coating
I've been doing powder coating for a while, just because I wanted to learn about it. Depending on the powder you shoot, it's usually 375 for 11-20 min in an oven, yes there are some structural concerns but if your not doing something structural, it's no big deal. If you end up doing it yourself, look at pre-heating it and wiping it down with MEK before you spray it and cook it. Do lots of research before you do it. It's a great surface and super hard to ruin. Just be aware that if you have something super precision, the powder coating can be quite thick! I'm not doing much of it anymore because of my job requirements but I'm always happy to answer questions! If you wanted a high performance coating, Valspar makes a rather unflattering coating for utility pipes that would literally rub the runway off before it dented the coating!
Best,
Brian
Brian Wallis
(Exempt AND VAF dues paid 02 FEB 16)
Callsign: VOODOO sold RV3 to pay for ratings !!!
AP/IA COM/Multi/IFR/350 type
