Go Back   VAF Forums > Avionics / Interiors / Fiberglass > GPS
  #201
Old 08-13-2019, 11:29 AM
g3xpert's Avatar
g3xpert g3xpert is offline
Post
Originally Posted by KAdriver View Post
Steve I am going with a single G5 and a GNX375 driving a trutrak AP. Only GPS source no nav radios or ILS. Will the G5 display course and Glide path (pink diamonds) by RS232 or will I have to add arinc box?
Hello Jason,
You will need to install a GAD 29. See page 7-17 of the Rev. 5 G5 Installation manual.
Note that your GNX 375 will also get pressure altitude from the G5 via the GAD 29, so you don't have to worry about any other connections for it to have everything it needs for ADS-B In/Out.
This diagram has some extra stuff, but we mainly want to point out that if you add the new GAD 13 with OAT probe and GMU 11 magnetometer, not only will the G5 display OAT, TAS, Winds, and Density Altitude, but the G5/GAD 29 will share this data with the GNX 375 allowing it to also display winds and other information.
Steve
Garmin G3X Support
g3xpert@garmin.com
