To those of you that have not decided where you are getting your panel my I suggest contacting Stein for a quote. I just finished installing my panel in my -10 that I bought from Stein Air. In my opinion they are world class when it comes to service and quality of workmanship. Through out the whole install process they were available every step of the way. I did not have one bad interaction with any the the folks that work there. They usually answer on the first ring and if they need to call you back they never miss. I fired up the panel yesterday with my son and we had one small issue that we had to call them on. They diagnosed the problem quickly and told me to check a few wiring connections and sure enough I flip flopped to wires in one D- sub. I reversed the two wires and the entire Garmin G3X system functioned perfectly. Stein Air is by far the most service oriented business I I've dealt with in my 70 years. I highly recommend them.
Tom Clark
N646LC
Soon to be airborne
Tom Clark
N646LC
Soon to be airborne
