Old 07-11-2018, 05:58 AM
humptybump's Avatar
Default Engine upgrade - paperwork
I'm writing a series of blog post detailing an engine upgrade on my RV-8. The posts are not in any particular order.
This post highlights the importance of words - specifically the difference between "certified" and "certificated". In the eyes of the FAA, the difference can be 35 hours of test flying
http://elder.ninja/blog/p/7480
- Glen, ESVA
Old 07-13-2018, 06:59 AM
gnuse's Avatar
gnuse gnuse is offline
Glad you got the weight of the paperwork low enough for the 8 to get back in the air.
George
"God does not deduct from one's time on earth that which is spent in the air."
Old 07-13-2018, 07:21 AM
Mel's Avatar
Mel Mel is offline
Basically the way the FAA uses the terms is:
Certified means that the device meets it's Type Certificate. Since our aircraft do not have a Type Certificate, typically, they are Certificated, meaning that they have been issued a Certificate.
A&P/EAA Tech Counselor/Flight Advisor/Nat'l Test Pilot School
<rvmel(at)icloud.com>
North Texas (8TA5)
RV-6 Flying since 1993, 172hp O-320, 3-Blade Catto (since 2003)Sold
Legend Cub purchased 12/2017
FRIEND of the RV-1
Eagle's Nest Mentor
Old 08-09-2018, 11:38 PM
ksdflying ksdflying is offline
Greatly appreciate you posting this. Huge help.
Thank you!
Old 08-12-2018, 09:13 PM
j-red j-red is offline
I read this a few months ago when you posted it, and have to wonder why we’re being given 40 hour initial phase 1’s for fresh builds instead of 25 hrs if we’re using “certificated” engine/prop combinations. Or are some RV builders successful in applying for and receiving the ahorter fly-off period?
As far as I’m aware, the o-360/Hartzell I’m putting on my 8 came right off of a Mooney. Does that mean I can apply for a 25 hour phase 1 period how would I go about proving it is a type-certificates combination?
Rebuilt RV-6A N94CR
RV-8 N803DR completed, flying.
Old 08-13-2018, 08:18 AM
bret's Avatar
bret bret is offline
I installed an engine and the prop off a Mooney with all the log books, and received a 25 Hr phase 1 program.
2019 gladly supported
