NorthernRV4
I'm at the point of adding all the internal details to the LH tank & ribs, fuel transfer holes, venting, fuel cap and the inboard rib. When ordering a bunch of new parts from Vans, I decided that I'd build one tank with the inverted pickup option. I've done quite a few searches and while it seems most build the LH tank with this option one could go either way.
Is there any advantage to having the inverted pickup in one tank or the other? I assume when flying aerobatics you still keep the fuel load balanced as best you can so one wing isn't heavy but does this actually work out in practice? Does the trap door modification to rib #2 keep the fuel in the first bay full? Are there recommended modifications other than what Van's shows in the plans?
For those that built an inverted tank did you add an inspection plate to the second rib bay and mount the sender to that the same way as it's done for the inboard rib? There is absolutely no detail for where to mount the sender in the rear baffle. Anybody have some advice here?
Comparing the -8 tank plans to the -4 it seems Van moved the location for the vent line fitting on the inboard rib. Wondering why and if there is an advantage to making the -4 the same way.
