sahrens
For those of you that installed an EarthX battery in your flying RV-7 I have a question.
How much did your CG shift aft when you replaced the original battery?
Do you have an aft CG issue at minimum fuel with your baggage compartment at max allowable weight? If so, what is you max baggage compartment weight at minimum fuel?
Thank you in advance for your answers.
