Old 01-14-2018, 07:03 PM
Jpm757 Jpm757 is offline
Scott,
All early RV6's were ONLY available with manual flaps, later Van offered the electric option and a retrofit kit. I loved the manual flaps on my -6 so much that I built them into my -7. They are simple and reliable. As others have stated, you need to acquire a -6 weldment for the retrofit. You will also need the internal button and spring parts. No big deal installing this setup, although some fabrication will be required for the latching arm and internal mechanism. You will also need to shorten the actuator arms (hex is way to go), also you can shorten the handle to your liking. Since you mentioned that you are not a "builder", you may want to get some assistance from an RV guy.
Good Luck.
Jake
Jake
RV6 completed 1991 sold.
RV7 #72018 N767T first flight 11/21/2017 150+ hrs.
IO-360M1B MT 3 blade, Dual AFS 5600.
1941 J3 Cub
2018 dues paid.
Old 01-14-2018, 07:07 PM
myrv6180 myrv6180 is offline
Default manual
Oh yes. my six has manual flaps and they came right off the Vans plans. Love'em.
Old 03-27-2018, 06:02 PM
pilotgabe's Avatar
pilotgabe pilotgabe is offline
Default Elect. Flaps
Hi I have a RV-6 with Manual flaps and I would be interested in your elect. flap components. If you'd like to do a straight across trade feel free to call me at 626-893-1774
Gabe
Old 03-27-2018, 08:24 PM
punkin punkin is offline
Default Elec. components
Hey gabe, I went ahead and converted with stuff I built after a kind VAFír sent me the page from the plans that detailed the manual flap setup.
I had several people tell me they were interested in the elec. setup, but no one actually pulled the trigger after I pmíd them.
No clue what itís worth; Iíve never had the issues with the motor that some have had, but I do believe it to be original (plane first flew in 1994).
Motor, sheet metal ďcoverĒcovered in vinyl, and part I cut off for actuator attachment...
Iím in Ecuador again until the 3rd of Abril, but feel free to shoot me a pm and let me know what itís worth to ya. I donít believe the sheet metal pieces will fit in a usps large flat rate box, but Iíd be happy to try.
Scott
1993 RV-6 (bought flying)
Double exempt but happy to contribute! Dues paid 2016, 2017
www.know-love.org
Old 03-27-2018, 08:27 PM
Default One more thing...
I love the setup. I actually 3d printed the button and slotted part of the plunger from ABS, and used a piece of aluminum between them. works like a champ. followed (I think it was Mel’s) advice and set the notches at roughly 13/26/39 degrees. I used this time to do what my a&p has been chiding me to do and swapped the actuator doohickeys from the homemade round ones to hex threaded ones, and adjusted to where I actually get a true zero degree flap now instead of about 1.5*.
For my style of flying (learning) in and out of short, rough, fields...it has been PERFECT! Love the manual flaps.
Scott
www.know-love.org
Old 03-27-2018, 08:31 PM
Mel's Avatar
Mel Mel is offline
Originally Posted by punkin View Post
I love the setup. I actually 3d printed the button and slotted part of the plunger from ABS, and used a piece of aluminum between them. works like a champ. followed (I think it was Melís) advice and set the notches at roughly 13/26/39 degrees.
Yep, That's my settings! Been flying that way since 1993 and wouldn't change a thing. BTW, I'm about to put my flaps up for sale. I'll even throw in the rest of the airplane as a bonus.
A&P/EAA Tech Counselor/Flight Advisor/Nat'l Test Pilot School
<rvmel(at)icloud.com>
North Texas (8TA5)
Legend Cub purchased 12/2017
FRIEND of the RV-1
Eagle's Nest Mentor
