Trim strip
Scott, it may not be a solution for you, but I made strips that fit the fuse so close there would be no need for rubber. About .032" cleareance on top and of course the bottom overlaps to occlude high pressure air. If this may aesthetically fit your preference, I can send you picks and discuss the simple process. The primary ingredient is PATIENCE not effort.
