I recently installed a panel mounted manual oil pressure gauge to back up the electric Rotax oil pressure sensor. In the process, I relocated the original sensor to the firewall to help improve the life of the sensor.
Everything worked great until the engine warmed up to operating temperature. Once the oil was hot, the pressure reading started fluctuating rapidly when viewed on the manual gauge. It was oscillating so rapidly that it made the gauge impossible to read. The Skyview also showed the pressure changes, but the fluctuations were dampened a lot, so it was not a big issue. I had observed the Skyview doing this in the prior 16 hours I have on the plane, but I chalked it up to "normal", thinking it was caused by sensor inaccuracies.
After spending a few frustrating days trouble shooting, I zeroed in on the oil pressure relief valve near the oil pump as the culprit. I inspected the spring and ball but found them to be in good shape. Some research on the Internet suggested that this was a known issue. In fact, I found out that Rotax sells an optional "piston valve" to replace the check ball to cure this very problem. Sure enough, I replaced the ball with the new piston valve and it cleared up the issue. Now the pressure readings are rock solid on both the Skyview and the manual gauge.
In case you guys run into similar issues, take a look at Rotax part number 857-230, "valve piston". It sells for a pricey sum of $30.00 (for what looks like a 25 cent part) but in this case I can say the investment was worth it.
After observing the wild and rapid fluctuations in the oil pressure, I have to wonder if it has been partially responsible for the early demise of the Rotax oil pressure senders that many have encountered.
