You may have to tighten the bolt past the present cotter pin holes, torque to 23-25 lbs of breakout force and drill new holes for the cotter pin. For what it's worth, do not put any grease on the Bellvile washers. Lubes defeat their purpose. This is mentioned in the plans/instructions. I have found that a little overtight of specs works better.
Cheers
