Ross7A-builder
Member
On page 7-5 of the wing kit instructions, under ?Fitting the attach angles...?, it says we should ?Remove the angles [T-712] and drill & rivet the nutplates to them...?. This sounds like the nutplates should be riveted to the attach angles. However, DWG 16A, detail A? looks like the nutplates are attached on the aft side of front spar W-706A-L. Should the nutplates be riveted to the attach angles or the spar?
