Instrument Lighting Control
If you are handy with a soldering iron, you can make one with parts from Radio Shack.
1 ea LM317T voltage regulator
1 ea 50K Ohm Potentiometer, # 271-1716 (R1)
1 ea 5.6K Ohm resistor. (R2)
You can use the capacitors shown but I skipped them for simplicity and there is no noise and it works fine for the Nu-lite rings and the LED eyeball floods that are pretty common.
I used some shoe goo to glue the 317T and resistor to the back of the potentiometer.
Probably 10 bucks total.
Schematic example
depends on how much current you need. a lm317T in a to-220 package is good for max 1A and gets hot as h..l at that power. a 3055 transistor in a to-3 is good for about 5 amps.
both will require proper heat sinking
bob burns
No argument against a possible better IC.
In my case, I was controlling a trio of Nulites and a few LEDs. Max of a 1/2 amp worst case. No perceptible temp rise on the TO-220 case shoe Goo'ed to the potentiometer housing.
Scott,
I have been using a single channel dimmer from Aircraft Spruce
PN 11-06674.
They spec.
Single Channel PWM dimmer
12 v DC. 7 amp cap (97 watts)
$33.75
It controls the lighting to my Vertical compass,and MGL V6 comm and a Garmin GMA 240 Audio Panel
Jack
Buy the parts asap - Radio Shack is in bankruptcy and is closing 1100 stores already.
An unfortunate testament to private citizens loosing skills to make things.
Shades of many science fiction stories of the future public reliance on machines they don't know how to fix.
Mooo.
Mooo.
id say it was due to the fact that they carried nothing but cheap **** that you can buy at any walmart cheaper. I needed a capacitor the other day that i was out of and they did not even carry them anymore.
bob burns
RV-4 N82RB
I just stumbled upon this article the builder put in my POH and then this thread popped into mind. I figured I would post it, but I do not know if this circuit is actually in my airplane, so I will not comment on how well it works. Next time I am at the hangar I will try to determine if this is what I have.
