I did not build my RV-6, bought it recently already flying.
I have a few questions about sealing the tip-up when it is closed. But first the status of why I'm asking the question to begin with.
My RV has several layers of a clear tape along the fuselage rails and the lip where the back of the canopy sits on the roll bar. These layers of tape are no longer stuck to the top of the fuselage. They are coming loose in long strips.
Build up was probably 1/16" to 3/32" thick, judging from the layers used.
Not sure what kind of tape it is, but it looks like it was used to seal the canopy when closed to keep the wind noise and rain out.
Is it possible to use normal weather stripping to seal the canopy?
I've read not to use electrical tape on the canopy as it can cause damage. Will the weather stripping also do this?
What other kind of issues am I asking for?
What could the clear tape be, is it something recommended for/by Vans?
The present tape doesn't look like any clear packaging tape or a scotch type tape.
What is the normal procedure for sealing the canopy?
Any help will be appreciated.
I fly down to KBOI to pick it up next week for the flight back to Alaska.
Thank you in advance for any help/advice provided!
