Old 02-02-2018, 11:42 AM
StuBob StuBob is offline
Default Questions on my Workmanship
I know what "perfect" looks like, but don't have a handle on "good enough." Two quick questions:
1) Scratches. These were caused by the squeezer while, if I recall correctly, I was standing on my head. Are these scratches something to fix when prepping to paint, something to buff out and prime over now, or absolute death to the part?
2) Gaps. There are places where my ribs weren't absolutely stuck down to the spar, resulting in gaps like this. Is this merely an aesthetic insult, or a threat to airworthiness? I've heard there's a guideline for allowable gap size, but can't find it.
Stu F.
Indianapolis (KMQJ)
Old 02-02-2018, 03:34 PM
wirejock's Avatar
wirejock wirejock is offline
Default Scratches and gaps
The old rule of thumb is any scratch you can catch a finger nail on is too deep and should be smoothed out. I think the rule is not to remove more than 10% of the thickness.
The gaps are a concern. I don't remember the two but it's not much. Maybe a few thousandth. I would drill out and try again. You can use a slice off some windshield washer rubber hose. Cut a section slightly thicker than the rivet tail. As you drive it, it squishes down and holds the parts tight.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
Old 02-02-2018, 04:26 PM
Davoakes@att.net Davoakes@att.net is offline
Stu,
What RV are you building I live East of Greenfield, not too far from you. I built a 7A and sold it and now planning the 14. Be glad to look some time if you wish.
Daveoakes
RV-7A N1243A Sold
#140479 RV-14A N1479B Reserved
Old 02-02-2018, 04:27 PM
JonJay's Avatar
JonJay JonJay is offline
Your fingernail will catch almost any depth of scratch, so I wouldn't judge off of that. Take a Scotchbrite pad, maroon, and take the scratch out in an oval pattern along the length of the scratch. If you sand through the Alclad, that is a pretty deep scratch, nominally about 5% of the sheet thickness. That doesn't mean it is ruined.
Although there is no specific standard called out by Vans, as Larry says, 10% is generally accepted as the maximum allowable reduction of thickness. This can be found in many airframe manuals for certified aircraft.
For the gaps between skins or flanges, a gap is allowed as long as a .002" feeler gage can not be inserted into the gap far enough to touch the rivet shank.
Go to Vans site and download the Mil specs from the FAQ page. It will help you with identifying what is acceptable and what is not with your riveting.
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
Old 02-03-2018, 06:46 AM
Thanks, Jay. I hadn't seen that before. It's absolute gold for the insecure builder who struggles with identifying not-perfect-but-adequte.
Stu F.
Indianapolis (KMQJ)
Old 02-03-2018, 07:12 AM
maniago's Avatar
maniago maniago is offline
This is good info. Recommend the thread be moved to General vs temp for posterity.
Mani
Mustang II (FoldingWing) "Firewall Fwd stage.Yea!" IO-360B1E,RSA,C2YR-BF/F7666-2,Superior sump,James; 2xHXr,MiniX,EIS,480,327,240,SL30,(maybe)Echo; SteamAlt,AS,VSI
Don't be a hater; I'm a cousin with thin wings!
N251Y (res)
Dec2017
Old 02-03-2018, 09:42 AM
JonJay's Avatar
Thanks Mani. There are several other very good resources that us early builders relied on before VAF was a thing.
Vans Build Manual - used to have basic technique, workmanship, hardware guides, and some standards. Not sure about the new manuals.
Ac-43-1b - although "obsolete", still an excellent resource.
Mil specs now found on Vans site.
Airframe manuals. I had a copy of a Cessna 152, King Air 90, and '42 Army Grumman Widgeon (most similar to RV). All have recommended repair procedures and references that are very helpful especially if you make a mistake.
General Aircraft Hardware Reference Guide available from General Aircraft Hardware company, or similar reference.
I am sure others can chime in on the resources they use. VAF is a wonderful resource but "trust and verify"....
Bucker Jungmann
RV1 - Proud Pilot.
Old 02-03-2018, 09:49 AM
I'd just as soon my scratches weren't preserved for posterity!
Stu F.
Indianapolis (KMQJ)
Old 02-03-2018, 09:53 AM
JonJay's Avatar
Those are badges of honor. Anyone who claims they didn't make a mistake on their build didn't build.
Bucker Jungmann
RV1 - Proud Pilot.
Old 02-03-2018, 02:28 PM
Ok, it's done. Sanded out all of those scratches and primed them. Stuck a 0.002" feeler gauge between those pieces and it didn't go, so that's done too.
Thanks, VAF!
Stu F.
Indianapolis (KMQJ)
