Old 01-19-2018, 09:00 AM
BBaxR6 BBaxR6 is offline
Default Can I build ailerons/flaps before the wings?
Hey guys/gals, my wing kit is arriving in a few weeks, and I was wondering if there's any compelling reason I can't build the ailerons/flaps first (just to lower the "daunting" factor a bit with all the wing jiggery/million hrs to prep wing ribs/etc). I searched around and saw some info about building them before the wing tanks, but didn't see anything about building them before the main wings. Thoughts?
Brandon
RV-7 Empennage complete; wings ordered!
http://bbaxrv7.blogspot.com/
Old 01-19-2018, 09:10 AM
wirejock's Avatar
wirejock wirejock is offline
Default Build order
No reason. I would recommend flaps first. Ailerons are more complicated. Personally I would just build in order.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
Old 01-19-2018, 11:39 AM
StuBob StuBob is offline
After the mess of the tanks and the monotony of the wings, the ailerons and flaps are a reward. Donít eat dessert first!
Stu F.
Indianapolis (KMQJ)
Old 01-19-2018, 12:57 PM
Thanks for the input! I'll continue to mull it over
Brandon
Old 01-19-2018, 02:15 PM
NavyS3BNFO NavyS3BNFO is offline
I built the ailerons and flaps first for the very reasons you mentioned. Also for space management. I just finished the flaps and am about to dig into the mains spars but so far no issues with doing things slightly out of order.
This questions has come up in the past and the general response is it is fine.
RV-8 empennage DONE
Wings in progress
Old 01-19-2018, 03:21 PM
Lemmingman's Avatar
Lemmingman Lemmingman is offline
The vertical stabilizer is very easy to build and was the first thing I made. I'd get your emp and start with the VS.
Gil Brice
McKinney, TX EAA-1246
RV7 - Working on fuse, fuel, brakes etc...
rvblog.thebrices.com
Old 01-19-2018, 10:11 PM
RV74ME RV74ME is offline
If the flaps/ailerons are dessert, the thousands of wing ribs (seemingly) are definitely the vegetables.
#deathbydeburring
Steve T.
N922WT (reserved)
KAUO (Auburn, AL)
RV-7 slow build
Tail kit COMPLETE
Wing kit COMPLETE
Fuselage kit COMPLETE
Old 01-19-2018, 10:39 PM
mfleming's Avatar
mfleming mfleming is offline
I did my flaps, then ailerons and then the wings.
In my case, I had about 2 months between finishing the empennage (at Synergy) and starting the wing kit. Doing the flaps and ailerons got me back in the building mode. When the wings were done, I was happy the control surfaces were ready to hang.
Michael Fleming
Joseph, OR
sagriver at icloud dot com
RV-7 Slider #74572
Started 11/2016
Donated and so should you
Old 01-20-2018, 05:56 AM
Thanks for the additional input everyone! I like the idea of using the flaps/ailerons to "get back into it" even though it's only been a few months since I finished the empennage.
Brandon
Old 01-20-2018, 06:21 AM
KatanaPilot KatanaPilot is offline
Default Check your work table!
Having recently built new flaps to replace the twisted QB flaps in my kit, I would stress the importance of having a very flat work table.
When I was at Synergy, we spent about 30 minutes shimming the work table we used to make sure it was very flat. It worked. The QB flaps from Van's had about 3 degrees of twist span wise. The flaps we built were 0.1 degree.
Krea Ellis
Locust Grove, GA
DA20-A1 "Princess Amelia" - gone home to Amelia Island
RV-7A Phase 2
RV-10 under construction at Synergy Air South
