ShortSnorter
Good Evening All - I'll cut to the chase.
I smeared the head of a 470AD4-7 on the VS-411PP (hinge bracket). I drilled the head and popped it out with a punch but could not for the life of me get the tail/shank out. I slowly drilled with a #40 bit a little at a time and trying to push it out after drilling a bit. I finally drilled through the rivet and ended up knocking/prying the shop head off with flush dykes. When the remnants of the rivet were finally removed, the shop head side of the hole seems to have a slight "countersink" appearance. The hole itself was not enlarged or mishaped from drilling. My question is: Can I replace with the same rivet? Replace with a slightly longer rivet to fill the slightly swollen hole? Start over? Below are some pictures of the empty hole and with a new rivet inserted. Thanks for all the help!
[/IMG]
[/IMG]
[/IMG]
